All powered nodes are dead
zofiel
Post by zofiel »
I don't know what is happening, but after install the new Qubino flush dimmer+ all my powered nodes are dead.
The battery nodes works perfect, and If I plugoff and then plugin a powered node, It lives around a minute and then go dead.
I try to read log in debug node, a node example:
2015-11-22 22:45:41.200 Error, Node008, ERROR: Dropping command, expected response not received after 1 attempt(s)
2015-11-22 22:45:41.200 Detail, Node008, Removing current message
2015-11-22 22:45:41.200 Detail, Node008, Notification: Notification - TimeOut
2015-11-22 22:45:41.200 Info, Node008, Sending (Send) message (Callback ID=0x1d, Expected Reply=0x04) - VersionCmd_CommandClassGet (Node=8): 0x01, 0x0a, 0x00, 0x13, 0x08, 0x03, 0x86, 0x13, 0x71, 0x25, 0x1d, 0x31
2015-11-22 22:45:41.324 Detail, Node008, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2015-11-22 22:45:41.324 Detail, Node008, ZW_SEND_DATA delivered to Z-Wave stack
2015-11-22 22:45:46.458 Detail, Node008, Received: 0x01, 0x07, 0x00, 0x13, 0x1d, 0x01, 0x02, 0x0e, 0xfb
2015-11-22 22:45:46.458 Detail, Node008, ZW_SEND_DATA Request with callback ID 0x1d received (expected 0x1d)
2015-11-22 22:45:46.458 Info, Node008, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2015-11-22 22:45:46.458 Warning, Node008, WARNING: Device is not a sleeping node.
2015-11-22 22:45:46.458 Error, Node008, ERROR: node presumed dead
2015-11-22 22:45:46.458 Warning, CheckCompletedNodeQueries m_allNodesQueried=0 m_awakeNodesQueried=0
2015-11-22 22:45:46.458 Warning, CheckCompletedNodeQueries all=0, deadFound=1 sleepingOnly=1
2015-11-22 22:45:46.458 Info, Node query processing complete except for sleeping nodes.
2015-11-22 22:45:46.458 Detail, Node001, Expected callbackId was received
2015-11-22 22:45:46.458 Detail, contrlr, Notification: AwakeNodesQueried
2015-11-22 22:45:46.458 Detail, Node008, Notification: Notification - Node Dead
2015-11-22 22:45:51.201 Error, Node008, ERROR: Dropping command because node is presumed dead
2015-11-22 22:45:51.201 Detail, Node008, Removing current message
2015-11-22 22:45:51.201 Detail, Node008, Notification: Notification - TimeOut
2015-11-22 22:45:51.207 Info, mgr, Manager::WriteConfig completed for driver with home ID of 0xf44e47b6
2015-11-22 22:45:51.208 Error, Node008, ERROR: Dropping command because node is presumed dead
2015-11-22 22:45:51.208 Detail, Node008, Removing current message
2015-11-22 22:45:51.208 Detail, Node008, Query Stage Complete (Versions)
2015-11-22 22:45:51.208 Detail, Node008, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Instances live=0
I follow this post to add qubino node: viewtopic.php?f=24&t=8550
Please help. Thanks a lot in advance.
bbqkees
Domoticz version: 4.1x
Re: All powered nodes are dead
Post by bbqkees »
well I do not think this will help but the config file for this device has changed in the mean time.
See the latest version here: https://groups.google.com/forum/#!topic ... h1TU-PiTHU
Which controller stick are you using?
zofiel
Post by zofiel »
reinstall all and now seems to be ok
new Qubino flush dimmer plus dead after a minute. I'm using last config file I think, downloaded today
bbqkees
Post by bbqkees »
I have a Aeotec Z2 USB stick and it will not work with this stick. I get the same problem.
It includes but turns dead after a minute or so.
My colleague uses the Z-Wave.Me stick and it works fine.
I did not have the time yet to do some more problem solving.
zofiel
Post by zofiel »
bbqkees wrote:I have a Aeotec Z2 USB stick and it will not work with this stick. I get the same problem.
Please Try:
1 - exclude all nodes
2 - Hard reset stick
3 - Reinstall Domoticz, deleting database and ozwcfg
3 - Include nodes from Domoticz, starting with the farthest (first powered nodes)
bbqkees
Post by bbqkees »
zofiel wrote: Please Try:
Could you tell me why I need to rebuild everything just for this one non-working ZWave device?
