GOCONTROL tested out
venyv
Post by venyv »
I picked up a GOCONTROL starter kit to see how well it worked last night. I had a few issues getting the stuff connected but once they were connected Domoticz picked the devices up.
The door sensor was by default was showing up as a light switch but that can be fixed. Once I got finish setting that up it always showed as Open and would never change status. Not really sure what the issue was with it and could not get it to work like a window/door sensor.
The Motion/Temp sensor worked half way. Domoticz only recognized the temp sensor and not the motion sensor. Another thing to note is that when you went to Devices in the menu it seemed to pick up the devices multiple devices for each sensor.
http://cl.ly/image/11040y1m1r1v
gizmocuz
Re: GOCONTROL tested out
Post by gizmocuz »
Could you post a link to the manual/hardware?
Seems this is a motion sensor, so yes, edit the switch and set the type to a motion sensor
some motion sensors does not send an 'off' command, if you edit the switch you can set the 'off delay' to 5 minutes (300 seconds) for instance
venyv
Post by venyv »
Yes it is a motion sensor but why do so many different devices come up for the one device?
That was my labeling for the GoControl Motion and GOCONTROL Temp.
I am able to see the temp sensor and I can get a reading for that but what kind of reading should I expect from the motion sensor if no one is in the room vs something or someone moving in the room?
adsi4nt
Domoticz version: 3.4834
Post by adsi4nt »
Not sure if you ever got this working. I am trying to get it setup and working without much luck. I am a newbie to Z-Wave and Domoticz and could use some help.
The link to the hardware is:
http://www.wink.com/downloads/help/goco ... sensor.pdf
http://www.wink.com/downloads/help/goco ... strobe.pdf
Any help or a can someone point me in a better direction for the GOControl devices? TIA
mzy2240
Post by mzy2240 »
Did you eventually make it work as it should be?
