Qubino ZMNHBD2 Flush 2 Relays (request for device support)
Posted: Tuesday 17 November 2015 16:22
I bought a new Qubino ZMNHBD2 Flush 2 Relays It's identified in Domoticz as a "Qubino ZMNHBD2 Flush 2 Relays"
I can control it (switch the relays on/off) from GUI. When the ZMNHBD2 is controlled by using the wall switch, Domoticz won't see the change. Nothing in the log.
Using Domoticz Version: 2.3589 on RPi2 and a Aeotec Z-Stick Gen5. OpenZWave USB Version: 1.3-526-g695402d
in "Groups and network" The controller (1) was added in all groups but 2 and 5. I tried to add "1" to group 2 and 5 as well but id didn't make any difference.
Thanks.
Below is an excerpt from the device configuration file:open-zwave/ChangeLog wrote:- Pull Request #665 - Add ZMNHBD2 Flush 2 Relay from emdioh (Justin)
<!-- Association Groups -->
<CommandClass id="133">
<Associations num_groups="8">
<Group index="1" max_associations="1" label="Lifeline (reserved for communication with the controller)" auto="true"/>
<Group index="2" max_associations="16" label="Basic on/off triggered at the change of output Q1 and reflecting its state" auto="false" />
<Group index="3" max_associations="16" label="Switch binary report triggered at the changes of output Q1 and reflecting its state" auto="true" />
<Group index="4" max_associations="16" label="Power meter report triggered at the changes of output Q1 and reflecting its state" auto="true" />
<Group index="5" max_associations="16" label="Basic on/off triggered at the change of output Q2 and reflecting its state" auto="false" />
<Group index="6" max_associations="16" label="Switch binary report triggered at the changes of output Q2 and reflecting its state" auto="true" />
<Group index="7" max_associations="16" label="Power meter report triggered at the changes of output Q2 and reflecting its state" auto="true" />
<Group index="8" max_associations="16" label="Multilevel sensor report" auto="true"/>
</Associations>
</CommandClass>
Sorry @gizmocuz but the urls are not valid on my system. Can You help me anyway?gizmocuz wrote:... To get your device supported email/attach the below results ( info @ domoticz . com): ...
Thanks.
