Danfoss LC-13
Posted: Tuesday 17 November 2015 16:19
by HansHofman
Is it possible to implement this option for the Danfoss LC-13
COMMAND_CLASS_PROTECTION
Set or get living connect® local protection mode.Possible local protection values are: 0 = no protection 2 = fully locked (tamperproof)
I want to lock the Danfoss so people cannot change settings.
Hans Hofman
Re: Danfoss LC-13
Posted: Tuesday 17 November 2015 16:24
by marczu83
+1 :)
Wysłane z mojego SM-G925F przy użyciu Tapatalka
Re: Danfoss LC-13
Posted: Tuesday 17 November 2015 20:00
by gizmocuz
in domoticz i think you can 'protect' this when editing the device,and check the protect checkbox ?
Re: Danfoss LC-13
Posted: Wednesday 18 November 2015 16:48
by marczu83
that's right but device is protected only from changes via website interface,
not from changes from device.
It would be nice to have such option :)
regards!
Re: Danfoss LC-13
Posted: Wednesday 18 November 2015 17:13
by Egregius
There should be a child lock on them, but I can't find how to activate it.
For me it doesn't mather. You may set whatever you want on the valve, my script will overwrite it within 10 seconds ;)
Re: Danfoss LC-13
Posted: Wednesday 18 November 2015 17:31
by stlaha2007
Seen some manuals, very short, on these Danfoss devices. Noticed the Childlock mentioned also.
Perhaps thats where the requested function comes in? Tried to find some info in Z-wave specs however didn't find it.
@egregius: nice your script rewrites the value. Its also temper prove then :D
Sent from my D6503 using Tapatalk
Re: Danfoss LC-13
Posted: Wednesday 18 November 2015 18:37
by gizmocuz
Okey, i see what you mean, and it means i have to add the protection class to the configuration options.
I tagged this message, and is on my todo list
for now, you can go to the hardware setup of openzwave, from the node dropdown, select 'control panel',
select the node, at the bottom select information, and you can set the protection options
Re: Danfoss LC-13
Posted: Friday 20 November 2015 19:25
by HansHofman
Thnx.
Any idea when will this be implemented ?
Hans Hofman
Re: Danfoss LC-13
Posted: Friday 20 November 2015 19:43
by gizmocuz
Don't forget, this is an open source project, made by people in their spare time
Probably tomorrow, but i can not prommise, the work around is good enough for now
Re: Danfoss LC-13
Posted: Saturday 21 November 2015 11:09
by gizmocuz
Not tested (my powernode does seem to ignore the protection settings, or maybe it is for manual operation only)
Beta #3626 now has the protection class in the settings of the node
Re: Danfoss LC-13
Posted: Monday 23 November 2015 18:47
by HansHofman
Works perfect on the Danfoss !!
Thnx
Would it be possible to set a maximum/minimum temp so users can change this to the max/min level.
I know its not an option of the Danfoss but it the Domoticz couls control the temp and set it back to the max/min level if exceeded.
Re: Danfoss LC-13
Posted: Monday 23 November 2015 19:17
by Abbadon
I cant test that becauses 'events' are not working for me. Try to make event:
if value of thermostat is higher than (for example) 26
then set value to 26
and the same solution for lower temp
Re: Danfoss LC-13
Posted: Tuesday 24 November 2015 7:55
by Egregius
Mine is controlled by PHP:
<?php
$Set = setradiator($TLiving, $RLiving);
if($RLivingZZ!=$Set) {Udevice($RILivingZZ, 0, $Set);}
if($RLivingZE!=$Set) {Udevice($RILivingZE, 0, $Set);}
if($RLivingZB!=$Set) {Udevice($RILivingZB, 0, $Set);}
First the desired setpoint for the valves is calculated based on the current room temperature and the dummy room setpoint.
Then whenever the valve has a different value than that it's updated.
Re: Danfoss LC-13
Posted: Tuesday 24 November 2015 12:39
by HansHofman
I set the protection level to no operation possible.
The Danfoss Thermostat is locked.
Next day the settings are not saved in the database the 900 is see screenshot.
The Danfoss Thermostat is not locked.
Version: 2.3678
Build Hash: 2351e80
Compile Date: 2015-11-23 09:14:59
Re: Danfoss LC-13
Posted: Tuesday 24 November 2015 15:00
by Abbadon
same for me, even when i change it on ozw config page still is unprotected
