Event Not Triggered
MightyMike
Domoticz version: 3530
Event Not Triggered
Post by MightyMike »
Can someone clarify why this event stoped working since the last update?
The lamp is not turned on automaticly, but if i turn it on my self after sunset, i can not get the lamp to go off (as expected because its later than sunset and before 00:00)
Same goes for turning it on before sunset, it wont go on because the event turns it off immediately (as expected)
bewo
Domoticz version: 2021.1
Re: Event Not Triggered
Post by bewo »
Is there something in the log?
I think the script is triggering itself in a loop, caused a time problem.
I would delete the section 00:00.
Only "< as Sunset and Lamp On then Lamp Off".
Individual projects:
Domoticz on a Intel Xeon Server | AeonLabs Z-Wave Gen.5 | RFXCOM RFXtrx433E USB | ESP-Wifi-Modules | Shellys
Wall-mounted 22" Touch Control Display (self construct) | LUA wind monitor| LUA heating control | and many many more :)
MightyMike
No there is nothing in the log file.
I also tried small if statements like
if time < sunset write to log "Before sunset"
even that event isnt triggered.
Ill try to remove the 00:00 part and see whats going to happen
Derik
Post by Derik »
try first a simple block
And the go to step to..
Time is > sunset until??
And from day 1 to day 2 you have to use always or in stead of and
Start simple
jvdz
Domoticz version: 4.107
Post by jvdz »
@Derik, you do realize you are replying to a spammer that posted in an 2+ years old thread? ;)
Jos
