Working: USB webcam as IP camera using mjpeg_streamer
Posted: Wednesday 11 November 2015 20:21
by Paul
following on from previous post it dawned on me to try this method.
So, compile mjpeg_streamer using this guide
http://blog.cudmore.io/post/2015/03/15/ ... pberry-pi/
Info on mjpeg_streamer parameters in this guide
http://skillfulness.blogspot.co.uk/2010 ... ation.html
Then the command line that worked for my old webcam is
/usr/local/bin/mjpg_streamer -i "/usr/local/lib/input_uvc.so -f 2 -r QVGA" -o "/usr/local/lib/output_http.so -p 9090 -w /usr/local/www"
My webcam may now run faster now I tracked down why w1_bus_master was hogging cpu
Then to set up in domoticz
just add a new camera, point it to domoticz ip address (or 127.0.0.1 I guess)
if you use the command line above then its port is 9090
then ImageURL is ?action=snapshot
nice!
Re: Working: USB webcam as IP camera using mjpeg_streamer
Posted: Wednesday 11 November 2015 22:58
by Paul
As a followup...
1. is a problem somewhere with w1-gpio/1-wire where is that?, guess I will find out soon as I want to use the raspberry gpio, but not 1-wire... i2c have temp sensors... though some nice metal encased 1-wire sensor assemblies...
2. at 2 frames a second low-res qvga (320x240) RPi load average is only 0.11, 0.10, 0.07, running domoticz (SD image) and mjpeg_streamer on same RPi B+ and viewing the stream in the domoticz web app on another computer, so no stress, good setup.
3. FYI and sure you will find it useful if you are an expert, I also install tmux to do testing, nice to detach/re-attach to a console over ssh or N consoles even... on one remote connection... persistent local user apps.
man the Linux universe is soo Cool!
