Why LUA script execute multiple times per second
Posted: Wednesday 11 November 2015 19:12
by rgroothuis
I've developed multiple LUA scripts, I recently noticed that my doorbell script is executed multiple times. Or even worse on one doorbell push I get multiple notifications over Telegram. This means the script is executed multiple times. I only have one doorbell script in the LUA script directory. What is causing this problem?
2015-11-11 19:07:51.783 (NestHuiskamer) Thermostat (HuiskamerTemperatuurInstelling)
2015-11-11 19:07:51.841 LUA: Motion sensor script started......
2015-11-11 19:07:51.850 LUA: Door Bell script started......
2015-11-11 19:07:51.826 (NestHuiskamer) Temp + Humidity (HuiskamerTemperatuur)
2015-11-11 19:08:00.350 LUA: -- Rene is at home, check when the lights need to be enabled.....
2015-11-11 19:08:00.497 Hardware Monitor: Fetching data (System sensors)
2015-11-11 19:08:00.519 LUA: Motion sensor script started......
2015-11-11 19:08:00.532 LUA: Door Bell script started......
2015-11-11 19:08:00.579 LUA: Motion sensor script started......
2015-11-11 19:08:00.592 LUA: Door Bell script started......
2015-11-11 19:08:00.647 LUA: Motion sensor script started......
2015-11-11 19:08:00.656 LUA: Door Bell script started......
2015-11-11 19:08:00.689 LUA: Motion sensor script started......
2015-11-11 19:08:00.698 LUA: Door Bell script started......
2015-11-11 19:08:00.746 LUA: Motion sensor script started......
2015-11-11 19:08:00.755 LUA: Door Bell script started......
2015-11-11 19:08:22.822 LUA: Motion sensor script started......
2015-11-11 19:08:22.831 LUA: Door Bell script started......
2015-11-11 19:08:22.807 (NestHuiskamer) Thermostat (HuiskamerTemperatuurInstelling)
2015-11-11 19:08:22.865 LUA: Motion sensor script started.....
Re: Why LUA script execute multiple times per second
Posted: Wednesday 11 November 2015 19:20
by jvdz
The Device lua scripts are started each time any device is updated.
So also when you update a device in your lua script ALL device scripts will be fired again.
Key is to only set commandArray actions when you really need to change anything.
Jos
Posted: Wednesday 11 November 2015 19:25
by rgroothuis
jvdz wrote:The Device lua scripts are started each time any device is updated.
Jos
Ok, clear. This means in that one (example) second I've 7 times a commandArray update. Otherwise I would not see that many script executions.
I need to find out which script is responsible for this. It is a bit strange because all my scripts have the following framework:
print('Motion sensor script started......')
if (devicechanged['MailBoxMotionDetected'] == 'On') then
    print('-- Mailbox usage detected  at '.. os.date("%d/%m/%Y %X") .. '!')
    -- os.execute('curl --data chat_id='..chatid..' --data-urlencode "text='..message..'"  "https://api.telegram.org/bot'..token..'/sendMessage" ')
The commandArray variable will only be set within that if statement if a device is changed.
Posted: Wednesday 11 November 2015 19:31
by jvdz
Correct so it is either one of your defined devices receiving an update or one of your scripts setting a commandArray['device']='something'.
Jos
Posted: Wednesday 11 November 2015 19:34
by rgroothuis
jvdz wrote:Correct so it is either one of your defined devices receiving an update or one of your scripts setting a commandArray['device']='something'.
Jos
Any suggestions on how to check/debug this? I just checked my LUA scripts and I cannot see a commandArray['device']='something' outside an if statement in which devicechanged is checked.
Is there a possibility in Domoticz so see which devices last have been changed?
Posted: Wednesday 11 November 2015 19:46
by jvdz
You could add a print() inside of the if when you actually set a command to be performed, then you know for sure, but actually you can already see it now because the log will contains a
record like this in case an action is performed:
EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_device_xyz.lua
One other thing I understood is that the current production version will fire all device events for all known devices, not just the enabled devices.
Jos
Posted: Wednesday 11 November 2015 19:51
by rgroothuis
Thanks Jos, your last comment is probably the reason. Because I don't see that:
line in my log file every X seconds.
So it is not originating from a LUA script that sets the commandArray[] incorrectly. It has to come from one device changes inside Domoticz. In this situation it would be nice if I could see in a total overview which devices had a status change at which moment in time.
Posted: Wednesday 11 November 2015 19:59
by jvdz
Guess you could just look at the devices view (Setup/Devices) and sort on date Last Seen. Maybe that gives you an idea.
Jos
