Popp smoke detector and siren 004001 configuration
cogliostrio
Post by cogliostrio »
I bought one of these smoke detectors to test, but Im having trouble getting the configuration working (nothing shows up in Domoticz). I currently have the below code.
Any suggestions as to what might be wrong is welcome.
<?xml version="1.0" encoding="utf-8" ?>
<Product xmlns='http://code.google.com/p/open-zwave/'>
	<CommandClass id="112" name="COMMAND_CLASS_CONFIGURATION">
		<Value type="short" genre="config" index="1" label="Siren alarm sequence interval" units="" min="3" max="129" value="10">
			<Help>The additional siren is creating a different acoustic signal differentiate from the smoke alarm. This sound is partly on and partly off. This parameter defines the total length of the interval in seconds. Available settings: 3 - 129. Default setting: 10</Help>
		</Value>
		<Value type="short" genre="config" index="2" label="Siren alarm tone length" min="0" max="3" value="3" size="1">
			<Help>The additional siren is creating a different acoustic signal differentiate from the smoke alarm. This sound is partly on and partly off. This parameter defines the total length of the sound versus silence within this interval. Available settings: 3 - 129. Default setting: 10</Help>
		</Value>
		<Value type="short" genre="config" index="3" label="Value of On-Command" min="0" max="99" value="99" size="1">
			<Help>Value 0-99. Default 99</Help>
		</Value>
		<Value type="short" genre="config" index="4" label="Value of Off-Command" min="0" max="99" value="99" size="1">
		</Value>
		<Value type="list" genre="config" index="5" label="Status of automated meshing of smoke alarms" min="0" max="3" value="3" size="1">
			<Help>This smoke detector can automatically inform other smoke detectors of same type about smoke alarms. They will then also turn on the siren. This function is a requirement of wireless networked smoke detectors</Help>
			<Item label="Value 0. Inactive" value="0" />
			<Item label="Value 1. Active (Default)" value="1" />
		</Value>
		<Value type="list" genre="config" index="6" label="Status of automated meshing of battery alarms" min="0" max="3" value="3" size="1">
			<Help>This smoke detector can automatically inform other smoke detectors of same type about battery alarms. They will then also turn on the siren. This function is a requirement of wireless networked smoke detectors.</Help>
		</Value>
	</CommandClass>
	<CommandClass id="133">
		<Associations num_groups="3">
			<Group index="1" max_associations="4" label="Lifeline" auto="true"/>
			<Group index="2" max_associations="4" label="Alarm reports" auto="true"/>
			<Group index="3" max_associations="4" label="Switching command when alarm" auto="true"/>
		</Associations>
	</CommandClass>
</Product>
wilcoyote
Re: Popp smoke detector and siren 004001 configuration
Post by wilcoyote »
the one below seems to work for me.
Anyway I've seen that the device reports 255 as default value for "on-command" instead of the expected "99". I don't know why. I adjusted the max to 255.
also I modified the manufacturer_specific.xml , adding the definition under Manufacturer id 0154.
	<Manufacturer id="0154" name="Popp">
                <Product type="0100" id="0201" name="4001 Smoke Detector and Siren" config="popp/popp4001.xml" />
Maybe try to exclude/include again the device after modifying the config and manufacturer file, and/or manually cleanup your "zwcfg_xxxx" file to remove the popp 4001 device defintion.
Hope this will help.
   <!-- Configuration -->
      <Value type="byte" genre="config" index="1" label="Siren alarm sequence interval" min="3" max="129" value="10" size="1">
      </Value>
      <Value type="byte" genre="config" index="2" label="Siren alarm tone length" min="1" max="99" value="8" size="1">
         <Help>The additional siren is creating a different acoustic signal differentiate from the smoke alarm. This sound is partly on and partly off. This parameter defines the total length of the sound versus silence within this interval. Available settings: 1-99. Default setting: 8</Help>
      </Value>
      <Value type="byte" genre="config" index="3" label="Value of On-Command" min="0" max="255" value="255" size="1">
         <Help>Value 0-255. Default 255</Help>
      </Value>
      <Value type="byte" genre="config" index="4" label="Value of Off-Command" min="0" max="255" value="0" size="1">
         <Help>Value 0-255. Default 0</Help>
      </Value>
      <Value type="list" genre="config" instance="1" index="5" label="Status of automated meshing of smoke alarms" min="0" max="1" size="1">
      </Value>
      <Value type="list" genre="config" instance="1" index="6" label="Status of automated meshing of battery alarms" min="0" max="1" size="1">
         <Help>This smoke detector can automatically inform other smoke detectors of same type about battery alarms. They will then also turn on the siren. This function is a requirement of wireless networked smoke detectors</Help>
      </Value>
   </CommandClass>
<!-- Association Groups -->
      </Associations>
   </CommandClass>
</Product>
d94pam
Post by d94pam »
Hi!
I also have the Popp smoke alarm/siren.
I have added the file you suggest and now I get proper devices. I can also see when a smoke alarm is going off.
However, I cannot trigger the siren and I cannot get temperature readings or battery level from the device. Any idea how I should solve this (siren being critical to my needs)?
starfish001
Post by starfish001 »
did anyone manage to control the siren?
cogliostrio
In another thread regarding a fibaro smoke detector, I think it was. someone said it was not possible to control the siren seperatly.
Why would you want to do this?
kmccor
Post by kmccor »
I'm interested in these as according to the manufacturer you can use the siren independently, which I want to tie into a security system. No use unless I can get it working in Domoticz though so I'd like to know whether this is possible.
vgr2
Post by vgr2 »
Any updates on this topic? I would like also control the siren seperatly.
antares
Post by antares »
As said above by @wilcoyote: change "on" value from 99 to 255 and "off" value from 99 to 0. I can now turn on the siren and it starts howling.
Cloud
Post by Cloud »
Got a new popp smoke detector, with the latest stable update the siren was included without problems and with no extra config. So perhaps just try to reinclude.
gl4di4tor81
Domoticz version: 3.5877
Post by gl4di4tor81 »
Hey guys,
got a popp smoke detector 004001 and inlcuded into domoticz. Siren is identified and can be switched on manually - use it for my alarming-system.
BUT: I don`t know why, this thing gives a beep in an unspecific time-period. the peep is just half a second or so, but drives me crazy.
Battery level is 100%, i also set
5. Status of automated meshing of smoke alarms: inactive
6. Status of automated meshing of battery alarms: inactive
anyone an idea?
PS: Rasp PI, Domoticz V 3.5877, OpenZWave USB Version: 1.4-2228-gbce4a88-dirty
gielie
Domoticz version: latest β
Post by gielie »
Its probably the battery, try to change it, I had the same problem. Battery level was at 100% for almost a year, impossible I thought so I changed the battery and the beep was gone.
I have a different issue, I connected them to the popp power adapter because I wanted them to function as a repeater but this doesn't work. I checked if the power adapter works properly by removing the battery and it does.
Did someone get the detector working as a repeater node?
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
