New value type V_CUSTOM and example
Posted: Sunday 08 November 2015 11:51
by gizmocuz
There is a new value type in MySensors (1.6 development branch) that can be used for various things.
For Domoticz the implementation is that you can request a sensor value (nValue/sValue) from Domoticz.
As an example i created a LCD sketch (16x2) that displays the outside temperature, the water/gas and power meter values:
Here is the sketch (a quick hack):
- MySensors V_Custom
- MySensorsVCustom.PNG (144.52 KiB) Viewed 6738 times
- Spoiler: show
/* LCDDisplay 16 character 2 line I2C Display Backpack Interface labelled "A0 A1 A2" at lower right. ..and Backpack Interface labelled "YwRobot Arduino LCM1602 IIC V1" MOST use address 0x27, a FEW use 0x3F */ // Enable debug prints to serial monitor #define MY_DEBUG // Enable and select radio type attached #define MY_RADIO_NRF24 //#define MY_RADIO_RFM69 #define MY_NODE_ID 254 #include <SPI.h> #include <MySensor.h> #include <Wire.h> #include <LiquidCrystal_I2C.h> #define CHILD_ID 1 // Id of the sensor child unsigned long POLL_FREQUENCY_TEMP = 30000; // Minimum time between send (in milliseconds). We don't want to spam the gateway. unsigned long POLL_FREQUENCY_POWER = 10000; unsigned long POLL_FREQUENCY_GAS = 62000; unsigned long POLL_FREQUENCY_WATER = 40000; MyMessage pollRequestMsg(CHILD_ID,V_CUSTOM); #define ID_TEMP_HUM_SENSOR_OUTSIDE 1771 #define ID_POWER_METER 1768 #define ID_GAS_METER 1773 #define ID_WATER_METER 2531 // set the LCD address to 0x27 for a 16 chars 2 line display // A FEW use address 0x3F // Set the pins on the I2C chip used for LCD connections: // addr, en,rw,rs,d4,d5,d6,d7,bl,blpol LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE); // Set the LCD I2C address #define LCD_WIDTH 16 #define LCD_HEIGHT 2 // Creat a set of new characters byte cdegrees[8] = { 0b01100, 0b10010, 0b10010, 0b01100, 0b00000, 0b00000, 0b00000, 0b00000 }; unsigned long lastTempPolled=0; unsigned long lastPowerPolled=0; unsigned long lastGasPolled=0; unsigned long lastWaterPolled=0; String LastPowerUsage; String LastGasUsage; String lastTemp; String lastHum; String lastWater; bool tempReceived=false; bool powerReceived=false; bool gasReceived=false; bool waterReceived=false; void CenterString(String &inText, const int width) { int osize=inText.length(); if (osize>=width) return; int padLeft=(width-osize)/2; for (int ii=0; ii<padLeft; ii++) { inText=" " + inText; } while (inText.length()<width) { inText=inText+" "; } } String SpaceStrings(const String &lString, const String &rString) { String lText=lString; int ibc = LCD_WIDTH - lText.length() - rString.length(); while (ibc>0) { lText+=" "; ibc--; } lText+=rString; return lText; } void setup() { LastPowerUsage="-"; LastGasUsage="-"; lastTemp="-"; lastHum="-"; lastWater="-"; lcd.begin(LCD_WIDTH,LCD_HEIGHT); // initialize the lcd for 16 chars 2 lines, turn on backlight lcd.createChar (1, cdegrees); // load character to the LCD lcd.backlight(); lcd.home (); // go home String sText; sText="LCD Display 1.0"; CenterString(sText, LCD_WIDTH); lcd.print(sText); lcd.setCursor ( 0, 1 ); // go to the next line sText="(c)2015 GizMoCuz"; CenterString(sText, LCD_WIDTH); lcd.print(sText); wait(1000); } void presentation() { // Send the sketch version information to the gateway and Controller sendSketchInfo("LCD Display", "1.0"); } void loop() { unsigned long currentTime = millis(); if ((!tempReceived)||((currentTime - lastTempPolled > POLL_FREQUENCY_TEMP))) { lastTempPolled = currentTime; //Request the temperature sensor send(pollRequestMsg.set(ID_TEMP_HUM_SENSOR_OUTSIDE)); wait(500); } if ((!powerReceived)||((currentTime - lastPowerPolled > POLL_FREQUENCY_POWER))) { lastPowerPolled = currentTime; //Request the Power sensor send(pollRequestMsg.set(ID_POWER_METER)); wait(500); } if ((!gasReceived)||((currentTime - lastGasPolled > POLL_FREQUENCY_GAS))) { lastGasPolled = currentTime; //Request the Gas sensor send(pollRequestMsg.set(ID_GAS_METER)); wait(500); } if ((!waterReceived)||((currentTime - lastWaterPolled > POLL_FREQUENCY_WATER))) { lastWaterPolled = currentTime; //Request the Water sensor send(pollRequestMsg.set(ID_WATER_METER)); wait(500); } wait(5000); } void PrintTempHumWater() { lcd.setCursor ( 0, 0 ); String lText,rText; lText=lastTemp; lText+=char(1); lText+="/"; lText+=lastHum; lText+="%"; rText=lastWater; rText+=" L"; String outString=SpaceStrings(lText,rText); lcd.print(outString); } void PrintPowerGasUsage() { lcd.setCursor ( 0, 1 ); String PText,GText; PText=LastPowerUsage; PText+=" W"; GText=LastGasUsage; GText+=" m3"; String outString=SpaceStrings(PText,GText); lcd.print(outString); } String getValue(String data, char separator, int index) { int found = 0; int strIndex[] = {0, -1 }; int maxIndex = data.length()-1; for(int i=0; i<=maxIndex && found<=index; i++){ if(data.charAt(i)==separator || i==maxIndex){ found++; strIndex[0] = strIndex[1]+1; strIndex[1] = (i == maxIndex) ? i+1 : i; } } return found>index ? data.substring(strIndex[0], strIndex[1]) : ""; } void receive(const MyMessage &message) { if (message.type==V_CUSTOM) { String cMessage = message.getString(); int idx = getValue(cMessage, '#', 0).toInt(); if (idx == ID_TEMP_HUM_SENSOR_OUTSIDE) { //0,temp,hum,humstatus tempReceived=true; lastTemp=getValue(cMessage, '#', 2); lastHum=getValue(cMessage, '#', 3); PrintTempHumWater(); } else if (idx == ID_POWER_METER) { //0,power usage powerReceived=true; LastPowerUsage = getValue(cMessage, '#', 2); PrintPowerGasUsage(); } else if (idx == ID_GAS_METER) { //0,gas usage gasReceived=true; LastGasUsage = getValue(cMessage, '#', 2); PrintPowerGasUsage(); } else if (idx == ID_WATER_METER) { //0,water usage waterReceived=true; lastWater = getValue(cMessage, '#', 2); PrintTempHumWater(); } else { Serial.print("Received unknown custom message from gw:"); Serial.println(cMessage); } } }
