Re: Getting error message with new domoticz version and rela
Posted: Saturday 14 November 2015 11:42
by fhwessels
HI here is the output from the serial monitor for the one sensor I am working on to understand why this is happing. I even upgrade to MySensor beta 1.6.0 to see if there was not a problem in ver 1.5.
Radio init successful.
Starting sensor (1.6.0-beta)
send: 79-79-0-0 s=255,c=0,t=17,pt=0,l=10,sg=0,st=ok:1.6.0-beta
send: 79-79-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
read: 0-0-79 s=255,c=3,t=6,pt=0,l=1,sg=0:M
send: 79-79-0-0 s=255,c=3,t=11,pt=0,l=11,sg=0,st=ok:Test Switch
send: 79-79-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.0
send: 79-79-0-0 s=9,c=0,t=1,pt=0,l=0,sg=0,st=ok:
send: 79-79-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,st=ok:
send: 79-79-0-0 s=2,c=0,t=3,pt=0,l=0,sg=0,st=ok:
send: 79-79-0-0 s=3,c=0,t=3,pt=0,l=0,sg=0,st=ok:
send: 79-79-0-0 s=4,c=0,t=3,pt=0,l=0,sg=0,st=ok:
Init complete, id=79, parent=0, distance=1
read: 0-0-79 s=1,c=1,t=2,pt=0,l=1,sg=0:0
read: 0-0-79 s=2,c=1,t=2,pt=0,l=1,sg=0:0
read: 0-0-79 s=3,c=1,t=2,pt=0,l=1,sg=0:0
read: 0-0-79 s=1,c=1,t=2,pt=0,l=1,sg=0:1
Posted: Saturday 14 November 2015 11:47
by fhwessels
Sendor is working right now:
read: 0-0-79 s=2,c=1,t=2,pt=0,l=1,sg=0:1
read: 0-0-79 s=4,c=1,t=2,pt=0,l=1,sg=0:0
read: 0-0-79 s=4,c=1,t=2,pt=0,l=1,sg=0:1
read: 0-0-79 s=3,c=1,t=2,pt=0,l=1,sg=0:1
restart Domoticz;
015-11-14 12:46:38.711 (MySensor NRF24) Lighting 2 (Security Sensor)
2015-11-14 12:46:40.696 Error: MySensors: Light command received for unknown node_id: 79, child_id: 2
2015-11-14 12:46:43.574 (MySensor NRF24) Lighting 2 (Security Sensor)
2015-11-14 12:46:44.851 (MySensor RFM69) Usage (Power Meter)
2015-11-14 12:46:44.880 (MySensor RFM69) General/kWh (Meter power)
2015-11-14 12:46:46.840 Error: MySensors: Light command received for unknown node_id: 79, child_id: 1
2015-11-14 12:46:48.463 (MySensor NRF24) Lighting 2 (Security Sensor)
2015-11-14 12:46:49.801 (MySensor RFM69) General/Voltage (Voltage)
2015-11-14 12:46:52.660 Error: MySensors: Light command received for unknown node_id: 79, child_id: 3
2015-11-14 12:46:53.326 (MySensor NRF24) Lighting 2 (Security Sensor)
2015-11-14 12:46:56.825 (MySensor NRF24) Lighting 2 (Security Sensor)
2015-11-14 12:46:59.000 (MySensor NRF24) Temp (Temp)
2015-11-14 12:46:59.052 (MySensor NRF24) General/Voltage (Voltage)
2015-11-14 12:46:59.312 Error: MySensors: Light command received for unknown node_id: 79, child_id: 4
2015-11-14 12:47:00.857 (MySensor RFM69) Humidity (Unknown)
2015-11-14 12:47:01.688 (MySensor NRF24) Lighting 2 (Security Sensor)
The to get the node to work have to restart that too:
Posted: Saturday 14 November 2015 13:32
by fhwessels
My relay sensor is now working after I upgrade to v2.3590. Also my ack work as well. If I power the relay sensor off and send a command to the node I get an error. Once I reconnect the sensors and I send a command to it start working and no error message from Domoticz!!!
If you look at the serial debug log you will now see that I getting an send command where I did not before.
send: 79-79-0-0 s=1,c=1,t=2,pt=0,l=1,sg=0,st=ok:1
send: 79-79-0-0 s=2,c=1,t=2,pt=0,l=1,sg=0,st=ok:1
send: 79-79-0-0 s=3,c=1,t=2,pt=0,l=1,sg=0,st=ok:1
send: 79-79-0-0 s=4,c=1,t=2,pt=0,l=1,sg=0,st=ok:1
send: 79-79-0-0 s=1,c=1,t=2,pt=0,l=1,sg=0,st=ok:0
send: 79-79-0-0 s=4,c=1,t=2,pt=0,l=1,sg=0,st=ok:0
