(SOLVED) Humidity sensor value change
usky73
Domoticz version: 2021.1
Post by usky73 »
I am trying to connect some thermal & humidity sensors using the update device option : dummy device creation and a php setting using the command describe in the wiki :
IP/json.htm?type=command&param=udevice&idx=IDX&nvalue=45&svalue=HUM;HUM_STAT
I did an example with this values :
IP/json.htm?type=command&param=udevice&idx=IDX&nvalue=45&svalue=34;3
The HUM_STAT value is sometimes considered but the humidity is not taken in account.
Do you have any idea ?
gizmocuz
Re: Humidity sensor value change
Post by gizmocuz »
If it is for a humidity only sensor (so not a temp+hum combo) the format should be
IP/json.htm?type=command&param=udevice&idx=IDX&nvalue=HUM&svalue=HUM_STAT
I corrected the wiki, hope it works now
usky73
Post by usky73 »
It works perfecly.
Thanks a lot !
