Hi fellow nerds,
I have a question regarding my Domoticz setup, perhaps someone can help me out. I wanted to start from a clean slate after upgrading some of my Z-wave devices and installed the latest stable version 2.3530 on my RPi B+ using the SD card image on a Diskpart formatted SD card. However, after upgrading, from version 2.2563 I think, my Zipato RGBW bulb doesn't want to change color anymore. All it does is giving me a dimmable white light. I tried a couple of obvious things already, soft & hard reset of the controller, removed the zwcfg_xxxx file excluded then reincluded the bulb several times, however without any luck. Went back to a SD card backup image from the previous version of my Domoticz installation and I could change color again. Any suggestions on how I could get the beautiful colors back in my house using the latest builds?
Cheers,
Coop
Zipato RGBW E27 Bulb doesnt change color after update 2.3530
Whatsek
- Domoticz version: Latest B
Re: Zipato RGBW E27 Bulb doesnt change color after update 2.
Gizmocuz is working on it, I have the same issue. If you are running on a raspberry pi, could you test the latest beta from today?
Cooper
- Domoticz version: 3.5406
Hi all, good news! Updated to latest beta for the RPi and the colors are back in my life again! Many thanks to all who contributed.Whatsek wrote:Gizmocuz is working on it, I have the same issue. If you are running on a raspberry pi, could you test the latest beta from today?
Cheers,
