ntp upgrade leads to error
Posted: Friday 06 November 2015 22:19
I downloaded the SD image, put it on the SD, launched my PI, then started update -> OK, but then
i entered sudo apt-get upgrade and the following happens:
The following packages will be upgraded:
ntp
1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/525 kB of archives.
After this operation, 4,096 B of additional disk space will be used.
Do you want to continue [Y/n]? Y
dpkg: error: parsing file '/var/lib/dpkg/available' near line 0:
EOF after field name `'
E: Sub-process /usr/bin/dpkg returned an error code (2)
pi@raspberrypi ~ $
Anyone an idea how to solve this?
Thanks,
DJ
ntp
pi@raspberrypi ~ $
Thanks,
DJ
