Page 1 of 3
New stable #3.521 Released today!
Posted: Saturday 31 October 2015 16:47
by gizmocuz
Hello fellow Domoticz users,
After months of hard work, we are proud to present a new stable version of domoticz !
Version #3.521
I want to give special thanks to all beta testers and fellow developers !
Rob
Re: New stable #3.521 Released today!
Posted: Saturday 31 October 2015 19:08
by bewo
Update works fine. The system seems to be a lot faster! Great job! ;-)
THANKS to all developers!
Posted: Saturday 31 October 2015 19:44
by sylvainsjc
Great job
Thanks you for your excellent work :D
Posted: Saturday 31 October 2015 20:52
by bewo
bewo wrote:THANKS to all developers!
BUT my system crashes after a few minutes...
This is the error in the log: (always the same):
2015-10-31 20:50:43.993  Error: Domoticz received fatal signal 11 !...
2015-10-31 20:50:44.010  Error:   /home/pi/domoticz/domoticz() [0x1636bc]
2015-10-31 20:50:44.011  Error:   /home/pi/domoticz/domoticz(_Z14signal_handleri+0x4c) [0x163768]
2015-10-31 20:50:44.011  Error:   /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer_v2+0) [0xb6b92b20]
I did an fresh install - the same problem. What can i do?
Same problem as here: viewtopic.php?f=6&t=8629
Posted: Saturday 31 October 2015 21:03
by Cybertom
My system crashes as well.
I've got the Segmentation fault and website is unresponsive.
after i placed back the lua script which i had removed because of update V2.3501 its seems to working again.
Edit. it's still crashing :cry:
Posted: Sunday 01 November 2015 8:31
by stuiow
Same problem here. Updated and not responding, on rpi.
Posted: Sunday 01 November 2015 10:46
by SweetPants
Updated production machine to 2.3521 stable on Ubuntu 14.04 64-bit on Intel NUC. Using Chrome, Firefox and Opera, no problems.
Posted: Sunday 01 November 2015 11:08
by sylvainsjc
Well I always use beta
updated yesterday with V2.3521 and all was fine
Updated this morning with V2.3524 and domoticz process take 100% of one core ans isn't responsive
I tried the domoticz.db V2.3521 backup but problem still there
I tried to restore domoticz repertory from V2.3521 backup but problem still there
I am now restoring full dd backup from this night
Wait & see :)
Posted: Sunday 01 November 2015 11:10
by safi78
SweetPants wrote:Updated production machine to 2.3521 stable on Ubuntu 14.04 64-bit on Intel NUC. Using Chrome, Firefox and Opera, no problems.
It's probably Pi related :(
Posted: Sunday 01 November 2015 11:18
by gizmocuz
For people that are experiencing problems, could you update to beta #3529 (or higher) and see if this solves the problem,
if yes, we need to make a new stable
Posted: Sunday 01 November 2015 11:46
by gizmocuz
Made a new release version, hope it solves the issue
Posted: Sunday 01 November 2015 12:05
by sylvainsjc
Problem was still here for me with night backup restoring but with last V2.3530, all seems ok now
This update was hot but you make a great job for all of us. Thanks :)
Posted: Sunday 01 November 2015 12:37
by bewo
I've updated now to 2.3530 and can confirm the system runs without crashes now (for 30 minutes). ;-)
But there is one new problem: All devices works fine, but my wall mounted iPad 1 gen. needs about 30 seconds to load the switches-page.
All other pages loaded in under a second. ???
I've cleaned the cache manually, deleted the shortcut, restart the iPad and generated a new shortcut, allowed cache over 10 Mb for domoticz, but it's the same....
All pages very fast - the switches page about 30 seconds.
Posted: Sunday 01 November 2015 12:38
by gizmocuz
maybe recreate the homescreen shortcut
the open safiry
browser to domoticz
from the bookmark menu, add the shortcut to the homescreen
Posted: Sunday 01 November 2015 12:41
by bewo
I've done this - no change.
Look yourself 2 minutes of video:
I've touched Switches at 0:12 and the site is loaded at 1:33 - so loaded (or waited) 1:21 :oops:
http://www.io-vof.de/bewo/Switches-Site.mp4
Hmm...... Don't know what it is....
Posted: Sunday 01 November 2015 13:02
by gizmocuz
bewo wrote:I've done this - no change.
that is way to long, i seem to have more switches, and it loads in 1.5 seconds
Send you a PM message to debug
Posted: Sunday 01 November 2015 17:08
by luisgcu
Hello folks,
I want to share my experiences after the update of domoticZ V2.3521, I am noob on the world of IOT so my system is very rudimentary and is more experimental that any other purpose, its been a lot fun playing with a raspberry pi for the very first time!
in my system I have several temperature sensor with Arduino with nrf2401 as transceiver sending the data to an ESP8266 as gateway all that is running MySensor library.
Yesterday I got the notification that an update was available, and I proceed using the web interface, after that the domoticZ v2.3521 ran for a few seconds and then it become irresponsible, I tried so many things without any luck.
Then I got new SD card and install the domoticz-raspberrypi-sdcard-3521 image, I have followed this guide http://www.domoticz.com/wiki/Domoticz_R ... i_SD_Image and domoticZ was working again without any issue..
Just today I set back the rpi the Sd card where I had the DomoticZ V2.3521 (updated using the domoticZ web interface) , and before it crashes I was able to go to Setup and pull the new update V2.3530, that update just run fine, no crashes after more than an hour running.
So far the only doubt that I have right now where I need a little bit more clarification is about the following.
I how do I now what software version is linked to stable and beta releases? how do I can go back quick ( without reinstalling everything ) to the previous version just in case any future web updates fail to work ?
quote[
Binary install update
Use the Web Interface to update Domoticz (Setup->Check for Updates)
If this fails for any reason (e.g. partial download giving segmentation fault) then you should manually update by:
Stable:
cd domoticz
./updaterelease
Beta:
cd domoticz
./updatebeta
] end quote
Posted: Sunday 01 November 2015 17:16
by gizmocuz
luisgcu wrote:Hello folks,
quote[
Stable:
cd domoticz
./updaterelease
Beta:
cd domoticz
./updatebeta
] end quote
We know the previous stable might had a problem, that is why we created a new version. (in less then 24 hours)
No need to explain that the previous had a problem, we know this (as you can read here)
I dont understand what your question is, because you also give the answer in your quoted text
Also you can never go back a version ever, we are backwards compatible, not upwards of course
Posted: Sunday 01 November 2015 17:28
by stuiow
Been running perfectly on 2.3530 now.
While the upgrade wasn't flawless originally, it was fixed bluddy quick so I wish to thank those responsible for getting it fixed so quick and in a stable release in less than 24hours from the last stable release!!
Not many developers would be able to achieve this!
So BIG THANKS!
Posted: Sunday 01 November 2015 19:30
by luisgcu
quote[
Stable:
cd domoticz
./updaterelease
Beta:
cd domoticz
./updatebeta
] end quote
Thanks for your promptly answer, I believe I got some how the confirmation that I need.. I need to read more .. thanks to all involved in the developing of this very cool software.
