Arduino DHT11 or DHT22 over 433MHz RFXcom
Posted: Wednesday 21 October 2015 17:09
by palmerfarmer
Slightly off topic:-
Does anynone know if its possible to use an arduino with a DHT11 or DHT22 to transmit over the 433MHz and recieve using one of the protocols the RFXtrx433E has?
I think someone has tried to emulate the oregon protocol but were using a different type of temp/humidity sensor.
Any ideas?
Re: Arduino DHT11 or DHT22 over 433MHz RFXcom
Posted: Wednesday 21 October 2015 20:26
by alexsh1
Oregon (OSV2 or OSV3) are using different sensors:
THGR122NX
THGN132N
THN132N
You do not need to have rfxtrx433e to transfer DHT22 temp/humidity. A simple Arduino nano (£4) or even ATTiny85/45 and transmitter (£2) would be good. Install the 433Mhz receiver on your RPi's SPI and you are good to go. Unfortunately, I do not have much experience with RFXcom so cannot help you with that one.
Posted: Sunday 25 October 2015 22:48
by palmerfarmer
Sorry I should have said the arduino is controlling a fan and extract unit by differentiating the data from 2 DHT22's, 1 inside and 1 outside, (this is all working) the temp and humidity is displayed on a local TFT screen. I am looking to transmit the data from the arduino to domoticz
Posted: Thursday 29 October 2015 23:13
by alexsh1
Your question is more about transferring data between Arduino and RPi.
Again can be done via 433mhz / 2.4ghz transceiver or/and a combination of a transceiver and rfxtrx433e
Posted: Friday 30 October 2015 10:05
by ThinkPad
Go the MySensors route, this will work fine and is native supported in Domoticz.
Build a MySensors gateway (i have the Ethernet version) and build a
temperature/humidity node.
Posted: Thursday 04 February 2016 19:51
by palmerfarmer
The My sensors route was/is definatley the way forward I have manged to do what i wanted and much more. Have been using this for months now. Many Thanks
