[solved] Cheap switching sockets from "OBI" issue
Posted: Wednesday 21 October 2015 8:34
Hi there
first try with RFLink...
first of all: Nice Work! Small cheap diy solder kit ... i'm verry ammused.
My issue or problem i have. got a cheap 3-pack of 433 mhz wall sockets from "OBI" (german diy-shop) and want to test it with rflink and domoticz.
with RFLink R32 the switch states were wrong... on was off and off was on...
with R33 the switching states are correct. so go on testing and learning. push the button (3, on) and theres is a, new, swiched on device in domoticz. push (3,off) it changed to off in domoticz. now add the switch for use and push on in domoticz...
aaaaand ... nothing happend... ;-(
here are some readings with the new amazing RFLink-Logger:
here i pushed the butten very short... if i press it longer there are more pulses and numbers ... but the fist codes are allways the same. also type, id, switch and cmd.
why does nothing happen when pushing butten in domoticz? do i anything wrong?
i will just repeat me .. sorry for my bad english
thanks for help
20;6B;DEBUG;Pulses=250;Pulses(uSec)=150,450,450,90,90,450,90,450,90,450,450,90,90,450,90,450,90,450,450,90,60,450,450,90,90,450,450,90,450,90,450,90,90,450,60,450,90,450,90,450,90,450,90,450,450,90,450,90,60,5550,90,450,450,90,90,450,90,450,90,450,450,90,90,450,90,450,90,450,450,90,90,450,450,90,90,450,450,90,450,90,450,90,90,450,90,450,90,450,90,450,90,450,90,450,450,90,450,90,90,5550,90,450,450,90,90,450,90,450,90,450,450,90,90,450,90,450,90,450,450,90,90,450,450,90,90,450,450,90,450,90,450,90,90,450,90,450,90,450,90,450,90,450,90,450,450,90,450,90,90,5550,90,450,450,90,90,450,90,450,60,450,450,90,90,450,90,450,90,450,450,90,90,450,450,90,90,450,450,90,450,90,450,90,90,450,90,450,60,450,90,450,90,450,60,450,450,90,450,90,90,5550,90,450,450,90,90,450,90,450,90,450,450,90,90,450,90,450,90,450,450,90,90,450,450,90,90,450,450,90,450,90,450,90,90,450,60,450,90,450,90,450,90,450,90,450,90,450,90,450,60,6990;
20;6C;TriState;ID=088a90;SWITCH=2;CMD=ON;
20;6D;DEBUG;Pulses=250;Pulses(uSec)=150,450,450,90,90,450,90,450,90,450,450,90,90,450,90,450,90,450,450,90,90,450,450,90,60,450,450,90,450,90,450,90,90,450,90,450,90,450,60,450,450,90,450,90,90,450,90,450,90,5550,90,450,450,90,90,450,90,450,90,450,450,90,90,450,90,450,60,450,450,90,90,450,450,90,90,450,450,90,450,90,450,90,90,450,90,450,60,450,90,450,450,90,450,90,90,450,90,450,90,5550,60,450,450,90,90,450,90,450,90,450,450,90,90,450,60,450,90,450,450,90,90,450,450,90,90,450,450,90,450,90,450,90,90,450,90,450,90,450,90,450,450,90,450,90,90,450,90,450,60,5550,90,450,450,90,90,450,90,450,90,450,450,90,60,450,90,450,90,450,450,90,90,450,450,90,90,450,450,90,450,90,450,90,90,450,90,450,90,450,90,450,450,90,450,90,90,450,60,450,90,5550,90,450,450,90,90,450,90,450,90,450,450,90,90,450,90,450,90,450,450,90,90,450,450,90,60,450,450,90,90,450,450,90,90,450,90,450,90,450,60,450,90,450,90,450,90,450,90,450,90,6990;
20;6E;TriState;ID=088a90;SWITCH=2;CMD=OFF;
10;rfdebug=off;
20;6F;RFDEBUG=OFF;
20;70;TriState;ID=088a90;SWITCH=2;CMD=ON;
20;71;TriState;ID=088a90;SWITCH=2;CMD=OFF;
20;72;TriState;ID=088a90;SWITCH=2;CMD=ON;
20;73;TriState;ID=088a90;SWITCH=2;CMD=OFF;why does nothing happen when pushing butten in domoticz? do i anything wrong?
thanks for help
