Backing up the Z-Wave network on Domoticz
BakSeeDaa
Post by BakSeeDaa »
I couldn't find any information about how to backup the Z-Wave network. I've spent a huge amount of time excluding all devices from my old HA-system and included them one by one into Domoticz. In case of that my Z-wave stick device ceases to work or gets stolen or whatever.
I've noticed there is a button in the OpenZWave Control Panel. It says "Backup Controller Changes need saving... " but nothing seems to happen if I push it.
BakSeeDaa
Re: Backing up the Z-Wave network on Domoticz
Post by BakSeeDaa »
It might be a noob-ish question but I still haven't figured out how to do it.
segordon
Post by segordon »
I'm coming to the conclusion that there is a fundamental limitation in Z-Wave due to the way that the protocol and most implementations work.
Z-Wave Controllers have unique Home IDs which are set at the factory - the Home ID is a 32-bit identifier which uniquely identifies an individual Z-Wave network.
Devices on a Z-Wave network can only talk to Controllers and other devices which share the same Home ID - During the process of inclusion the Home ID of the Controller is copied to the included device; this device can now talk to the controller and other devices on the same Z-Wave network.
The problem is that if your Z-Wave controller fails (or is lost/stolen/destroyed), even if you have a back-up of the previous configuration it will be useless because your replacement controller will have a different Home ID and so will not be able to access the previously configured Z-Wave devices since they will only talk to a controller with the original Home ID.
This means that unless your controller supports the ability to manually set its Home ID (and to restore the network topology/routing tables etc.) then when replacing a controller the only option is to manually re-include all your existing devices.
This limitation also applies to most Z-Wave sticks, as the ability to back-up and restore the Z-Wave chip configuration requires an extension to the normal Z-Wave API.
As far as I know the Aeon Labs Sticks do not support this feature, but the Z-Wave.me sticks claim to have an extended API which allows "back-up and restore of network topology" - although it is unclear if this includes the Home ID.
I'd love to be proved wrong about this, but the information I've found so far seems to agree with this.
BakSeeDaa
Post by BakSeeDaa »
Thank You @segordon for your detailed answer.
What You say make sense. However I migrated to Domoticz from a Vera Controller. It had the ability to backup the Z-wave network and it can be restored on a different unit. I remember I did that once when i had to replace my controller. I don't know how Vera does it but it works.
segordon
Post by segordon »
@BakSeeDaa you are correct, Vera does support this capability, as does the Z-Wave.me UZB stick and RaZberry PI Z-Wave board.
Both the UZB stick and RaZberry PI board support back-up and restore through the Z-Way app (look at the top of page 12 in this doc: http://www.vesternet.com/downloads/dl/f ... manual.pdf).
So in theory if you used a UZB stick, or RaZberry PI board for your Domoticz controller you could back up the chip using Z-Way - however the Domoticz wiki states that there is no support for running Z-Way at the same time as Domoticz so it may be necessary to shutdown Domoticz to perform the backup/restore operation using Z-Way. (https://www.domoticz.com/wiki/Raspberry ... ghter_Card)
I've just ordered a UZB stick to test out this feature and I'll post an update when I have had a chance to try out the backup/restore feature in conjunction with Domoticz.
In theory, since UZB & RaZberry PI both support an extended API it should be possible for Domoticz to recognise this and offer the additional features in the UI - although this would mean that the underlying OpenZWave stack would also need to support the extended API, which I'm not sure it does...
segordon
Post by segordon »
So I've done a bit of testing with he RaZberry PI Board on a PI 2 and the UZB stick on a Linux box.
Using the Z-Way software both of these options allow the backup of the network + controller info, but when I try to restore the backup it kills the Z-Way server process and deletes a bunch of config files so the only option is to run the z-way installer process again to get it working.
I've also tried the UZB device with Domoticz and it works fine, however in the OpenZWave Control Panel I still the "Backup Controller Changes need saving... " message, and clicking the backup button does nothing - so Domoticz/open-zwave do not appear to detect that the UZB stick can back-up the controller data (or maybe this option is not yet implemented in the OpenZWave control panel....?)
So my current plan is to stick with the Aeon Labs Gen 5 Z-Wave stick as at least I can use its battery feature to go around and re-include z-wave devices in the event of a controller failure....
BakSeeDaa
Post by BakSeeDaa »
segordon wrote:So I've done a bit of testing with he RaZberry PI Board on a PI 2 and the UZB stick on a Linux box.
Thanks for doing all the testing. Let's hope that backing up Z-wave network will be properly implemented in the future.
boom88
Post by boom88 »
Hello. I've been in contact with Aeon labs and they assured me the new controller will support backup/restore feature. The controller should be release somewhere between December 15th and mid January.
