Gigaset Elements Cli - domoticz support
Posted: Monday 12 October 2015 16:42
I have started to add Domoticz support to my (python based) Gigaset Elements cli which can be found on PyPI and GitHub.
https://github.com/dynasticorpheus/gigasetelements-cli
[FUNCTIONALITY]
[TO-DO]
* Set system and sensor status at initial startup
* More sanity checks
* Tell me ...
[INSTALLATION]
In case you want to test please follow below steps:
1. Go to Setup / Hardware in Domoticz GUI
2. Add hardware - dummy
3. Create a virtual sensor - type Alert for basestation (remember the idx number)
4. Create a virtual sensor - type Manual Light/Switch for each motion/door/window/siren/plug/button/camera (remember their idx numbers)
5. Set Off Delay to 2 seconds for virtual sensors linked to motion, button or camera
6. Install gigasetelements-cli using PyPI or GitHub
PyPI
GitHub
7. Download config file and add username and password
Config file will be automatically loaded if found in one of the below locations. Use --config to specify an alternative location.
8. Run below command to get sensor ids and match them with the their respective idx in domoticz
9. Run below command to get camera sensor id. Use the 12 uppercase digits in stream url. This MAC address can also be found on the back of
the camera.
10. Fill out collected details in the [domoticz] section in the config file.
11. Do a test run of the of the program to see if everything is working as expected.
12. Once working start with additional arguments so it runs as daemon, automatically restarts in case of errors and creates a log file.
In case you can't get it running please feel free to post your issue in this thread.
[CUSTOM ICONS]
I extracted the icons used in the adroid app and created a custom set for domoticz. [BUGS]
https://github.com/dynasticorpheus/giga ... cli/issues
[SUGGESTIONS]
Idea's & suggestions are more than welcome so please let me know. If you like it please star this project on github:
[UPDATE]
Added base to custom icon set and update domoticz screenshot - 12/02/16
Updated install instruction - 08/05/16
Updated custom icon set to avoid conflicting names - 23/05/16
Update url's - 31/05/16
Added smoke to custom icon set - 01/06/16
Cheers
Dynasticorpheus
[FUNCTIONALITY]
Gigaset Elements - Command-line Interface by [email protected]
optional arguments:
-h, --help show this help message and exit
-c CONFIG, --config CONFIG
fully qualified name of configuration-file
-u USERNAME, --username USERNAME
username (email) in use with my.gigaset-elements.com
-p PASSWORD, --password PASSWORD
password in use with my.gigaset-elements.com
-n TOKEN, --notify TOKEN
pushbullet token
-e EVENTS, --events EVENTS
show last <number> of events
-d DD/MM/YYYY DD/MM/YYYY, --date DD/MM/YYYY DD/MM/YYYY
filter events on begin date - end date
-o HH:MM, --cronjob HH:MM
schedule cron job at HH:MM (requires -m option)
-x, --remove remove all cron jobs linked to this program
-f {door,window,motion,siren,plug,button,homecoming,intrusion,systemhealth,camera,phone,smoke}, --filter {door,window,motion,siren,plug,button,homecoming,intrusion,systemhealth,camera,phone,smoke}
filter events on type
-m {home,away,custom}, --modus {home,away,custom}
set modus
-k DELAY, --delay DELAY
set alarm timer delay in seconds (use 0 to disable)
-D, --daemon daemonize during monitor/domoticz mode
-z, --notifications show notification status
-l LOG, --log LOG fully qualified name of log file
-R, --rules show custom rules
-P PID, --pid PID fully qualified name of pid file
-s, --sensor show sensor status (use -ss to include sensor id's)
-b {arm,disarm}, --siren {arm,disarm}
arm/disarm siren
-g {on,off}, --plug {on,off}
switch plug on/off
-a, --camera show camera status
-r, --record switch camera recording on/off
-A, --snapshot download camera snapshot
-t, --monitor show events using monitor mode (use -tt to activate
domoticz mode)
-i, --ignore ignore configuration-file at predefined locations
-N, --noupdate do not periodically check for updates
-j, --restart automatically restart program in case of a connection
error
-q, --quiet do not send pushbullet message
-I, --insecure disable SSL/TLS certificate verification
-S, --silent suppress urllib3 warnings
-v, --version show version[TO-DO]
* Tell me ...
[INSTALLATION]
PyPI
pip install gigasetelements-cliCode: Select all
git clone git://github.com/dynasticorpheus/gigasetelements-cli.git
cd gigasetelements-cli
python setup.py install --forceCode: Select all
curl -o ~/.gigasetelements-cli/gigasetelements-cli.conf https://raw.githubusercontent.com/dynasticorpheus/gigasetelements-cli/master/gigasetelements-cli.conf.templateCode: Select all
/opt/etc/gigasetelements-cli.conf
/usr/local/etc/gigasetelements-cli.conf
/usr/etc/gigasetelements-cli.conf
~/Library/Application Support/gigasetelements-cli/gigasetelements-cli.confCode: Select all
gigasetelements-cli -ssthe camera.
gigasetelements-cli -a11. Do a test run of the of the program to see if everything is working as expected.
gigasetelements-cli -tt
gigasetelements-cli -tt --restart --daemon --log /tmp/gigasetelements-cli.log[CUSTOM ICONS]
[SUGGESTIONS]
[UPDATE]
Cheers
Dynasticorpheus
