Page 1 of 2
synology package : how to use x10 protocol
Posted: Saturday 10 October 2015 13:13
by pipitch
I want to switch my domoticz installation from raspberry to synology but I have some X10 devices.
How I can install mochad (or another) inside the synology to use X10 protocol.
I don't want to use chroot to do this.
Re: synology package : how to use x10 protocol
Posted: Saturday 10 October 2015 14:59
by G3rard
Maybe you can use the following link from a Dutch Synology forum
http://www.synology-forum.nl/algemeen/x ... -synology/.
Posted: Saturday 20 February 2016 10:36
by franzelare
@pipitch: did you get it working?
I'm struggeling, on my Pi mochad workes fine, on my synology not.. and forwarding the switches works most of the time, but sometimes the status is displayed wrong on my synology... so that's why I would love to get mochad up and running on my synology
Posted: Sunday 21 February 2016 8:25
by pipitch
Yes and No. I use synology for all except x10. For the X10, I send the command to a raspberry (mochad is installed on rapsberry)
It's not the best way, but I will change my x10 device by zwave device.
Posted: Sunday 21 February 2016 12:44
by franzelare
hmmm, than I just keep trying... since I have my entire house with x10 power line devices, since getting them in sync all the time will also be a lot of work.
I will let you know when I get it up and running!
Posted: Sunday 21 February 2016 14:13
by jumbotroll
Maybe I can cross compile the mchad binary into my domoticz package for synology, is that helping?
Posted: Sunday 21 February 2016 14:36
by franzelare
if that's possible, would be great!
it would also need libusb 1.0 or higher to work
Posted: Sunday 21 February 2016 14:59
by jumbotroll
franzelare wrote:if that's possible, would be great!
Libusb 1.0 is included in domoticz package also.
I can compile a test for you.
What NAS do you have and DSM version?
Posted: Sunday 21 February 2016 20:09
by franzelare
I have a synology DS114 running on DSM 5.2-5644 Update 5
is that enough?
Posted: Sunday 21 February 2016 20:46
by jumbotroll
Deleted, see next post.
Posted: Monday 22 February 2016 11:46
by jumbotroll
Edit:
Packages deleted.
The package is reported not working
Posted: Monday 22 February 2016 17:57
by franzelare
I have a MARVELL Armada 370
which package should I install?
Posted: Monday 22 February 2016 18:39
by jumbotroll
Edit.
Deleted
Posted: Tuesday 23 February 2016 19:32
by franzelare
first time I will install a beta package.
I should stop domoticz, manually install this package?
Posted: Tuesday 23 February 2016 20:03
by jumbotroll
franzelare wrote:first time I will install a beta package.
Take backup of db and reinstall if you have a very old version.
Posted: Tuesday 23 February 2016 22:42
by jumbotroll
Edit:
The package is reported not working.
Posted: Friday 26 February 2016 9:28
by franzelare
hmm, i was planning to give it a try today, if you have an other revision, or have an idea how to get rid of my message:
configure: error: C compiler cannot create executables
Posted: Friday 26 February 2016 16:18
by jumbotroll
franzelare wrote:hmm, i was planning to give it a try today, if you have an other revision, or have an idea how to get rid of my message:
I have build standalone packages for mochad and netcat you can test.
You must install both packages.
http://www.jadahl.com/synology/?arch=armada370
Posted: Friday 26 February 2016 17:32
by franzelare
from the command line or from the package center?
Posted: Friday 26 February 2016 17:43
by jumbotroll
franzelare wrote:from the command line or from the package center?
Package center
I don't build bootstrap packages.
