ZMNHAD1 on/off switch added to openzwave
shaun
Post by shaun »
I just bought qubino ZMNHAD1 on/off micro switch, they wasn't recognized by open zwave and domoticz so I created the xml config and add them to the manufacturer_specific.xml.
You can find the files in my git https://github.com/wackoracoon/open-zwa ... ter/config
I made a pull request to integrate my change to openzwave but if you can't wait you can download both files, build again open zwave and domoticz to enjoy the module parameters configuration.
djoeney
Re: ZMNHAD1 on/off switch added to openzwave
Post by djoeney »
Could you tell if these new modules collect power usage the right way? If have 2 types of modules Qubino ZMNHDA2 Flush Dimmer this type does a good job measuring power usage. Only i have a Qubino ZMNHAA2 Flush 1 Relay which have a strange behavior in measuring power usage i have a 5 watt LED connected and the module says usage from 20 to 300 watt.
Waiting for this module to come to the Netherlands.
Compute RPi 2 : Domoticz latest beta, Synology : Domoticz tested beta on failover system.
Peripherals RFXCOM - RFXtrx433, Z-Wave.Me ZME_UZB1 USB Stick,P1 cable on smartmeter, Logitech Harmony Hub, 3 IP camera's
juankar
Domoticz version: 4.
Post by juankar »
Hello
Does it report status when switched manually (with wall switch) or need polling?
