OpenZwave start/stop
pluggin
Post by pluggin »
Hi everyone!!
Some times my zwave network stop responding and I dont want to reboot my PI or restart Domoticz so I want to start or stop only Openzwave driver from a script. Just like we do from webpage Setup/hardware (disable/enable).
Is this posible?
Razberry + 4 Eversrping HSM02 + 2 Aeotec Multi-Sensor + 1 Aeotec Micro Dimmer + 4 Aeotec Micro Smart Energy Switch, 2nd + 1 Remotec ZXT-120 + 1 Aeotec Smart Energy Monitor + 1 Everspring SE812 indoor Siren + 2 fibaro motion sensor + Aeotec water sensor
pluggin
Re: OpenZwave start/stop
Post by pluggin »
Looking and searching I can do it with Json...
Query the Hardware with:
/json.htm?type=hardware&filter=all
"Address" : "",
"DataTimeout" : 0,
"Enabled" : "true",
"Mode1" : 0,
"Mode2" : 0,
"Mode3" : 0,
"Mode4" : 0,
"Mode5" : 0,
"Mode6" : 0,
"Name" : "CHome",
"NodesQueried" : true,
"Password" : "",
"Port" : 0,
"SerialPort" : "/dev/ttyUSB20",
"Type" : 21,
"Username" : "",
"idx" : "2",
"version" : "1.3-293-ga4ea66b-dirty"
Then only change Enable values to true or false.
/json.htm?type=command&param=updatehardware&htype=21&port=%2Fdev%2FttyUSB20&address=&name=XX&enabled=XX&idx=2&datatimeout=0&Mode1=0&Mode2=0&Mode3=0&Mode4=0&Mode5=0&Mode6=0
Thats all
stanim
Post by stanim »
I would like to do the same, but with a specific protocol (enable/disable FineOffset).
It would be nice if somebody could give me the correct API command to do this.
Thanks in advance
nayr
Domoticz version: github
Post by nayr »
I dont believe I have seen that functionality exposed for the API's, I can see a need to request it though.. for example when I was investigating a fallover setup the ability to restart the hardware via API would be required.
