Enable/disable timer from events / LUA script Topic is solved
rdebruijn
Post by rdebruijn »
Option to enable / disable a (set of) timer(s) for a switch/device from within events (blockly) or via a LUA script would be very welcome.
Screenshot to illustrate:
Paulyoh
Domoticz version: 2023.1
Re: Enable/disable timer from events / LUA script
Post by Paulyoh »
+1
Im also looking for this. :)
Se this post for info: http://www.domoticz.com/forum/viewtopic ... 4323#p4287
asdfgh1234
Post by asdfgh1234 »
I have an Arch Linux
It works with this workaround :-)
ENABLE
in LUA script (script_device_xxx.lua):
os.execute ("/opt/domoticz/scripts/sql.sh 24 1")
24 is idx
1 is Activate
then in SH script (sql.sh):
#!/bin/bash
sqlite3 -header /opt/domoticz/domoticz.db "UPDATE SetPointTimers SET Active = $2 WHERE DeviceRowID = $1 AND Active <> $2;"
DISABLE
in LUA script:
os.execute ("/opt/domoticz/scripts/sql.sh 24 0")
Eduard
Post by Eduard »
Also possible on Domoticz with JSON: (since august 27 :D )
Enable timer:
http://<ip>:<port>/json.htm?type=command&param=enabletimer&idx=1
Disable timer
http://<ip>:<port>/json.htm?type=command&param=disabletimer&idx=1
Enable scene-timer
http://<ip>:<port>/json.htm?type=command&param=enablescenetimer&idx=1
Disable scene-timer
http://<ip>:<port>/json.htm?type=command&param=disablescenetimer&idx=1
Show all timers:
http://<ip>:<port>/json.htm?type=command&param=gettimerlist
Show all scene-timers:
http://<ip>:<port>/json.htm?type=command&param=getscenetimerlist
Have fun!
PS: Not advisable to edit the DataBase at runtime in my opinion, that why i wrote these extra JSON-calls ;)
clkoolen
Post by clkoolen »
Hi Eduard,
Could you elaborate on if and how to make these json URL's work with the blockly? I tried the setup in the image below:
Event with json.PNG (26.58 KiB) Viewed 10584 times
It changes the state of the control variable. In the log I can see it tried to fetch the URL:
but there is no change of state in the timer list. If I try the same URL from my browser it works fine.
Entry Timerlist.PNG (5.05 KiB) Viewed 10584 times
Help would be very much appreciated.
Casper
Eduard
Post by Eduard »
Sorry, i can't tell you why the blockly is not working because i don't use them. I only use (bash/python) scripts to fire the json calls.
Verzonden vanaf mijn iPad met Tapatalk
clkoolen
Post by clkoolen »
Hi Eduard,
As a complete NOOB to Domoticz (started two weeks ago) and pyton scripts could you elaborate in how to process a json call into a script?
My main intention in enabling and disabling timers is that I would like to create a "holidays" button that will activate and deactivate a set of timers that will turn lamps on and off in the house. Next to that I would also like to check the sunrise and sunset times to decide if the outdoor lamps should be turned on or not. Blockly appeared to be ideal for this, but unfortunately I cannot get it to work for me. Next to that the timer functions that can be associated to the buttons are very easy to use and versatile enough except for the problems described above.
Any help on calling the json commands in a python script is very welcome. After that I think I will be able to get it to work for me no problem.
Thanks for the help.
Eduard
Post by Eduard »
Here is a simple python example
import urllib2
domoticzserver   = "127.0.0.1:8080"
domoticzusername = ""
domoticzpassword = ""
base64string = base64.encodestring('%s:%s' % (domoticzusername, domoticzpassword)).replace('\n', '')
def DomoticzRequest (url):
  request = urllib2.Request(url)
  request.add_header("Authorization", "Basic %s" % base64string)
  response = urllib2.urlopen(request)
  return response.read()
url = "http://" + domoticzserver + "/json.htm?type=command&param=enabletimer&idx=1"
DomoticzRequest(url)
Hope it get's you started!
G3rard
Domoticz version: No
Post by G3rard »
clkoolen wrote:Hi Eduard,
Other possibilty is to activate the Holiday timer. This option can be found at Setup-Settings-Other-Timer Plan. When Holiday timer is actived, you can set other timers then in the default plan.
Not using Domoticz anymore
clkoolen
Post by clkoolen »
Hi Eduard,
Thanks for the script example. I got it to work with the addition of import base64.
Now I will have to make it do my desired changes.
Thanks again.
clkoolen
Post by clkoolen »
Ended up creating a single script that would check a specific group is on or off.
Then depending on the state it enables or disables a set of timers by the id's.
#!/usr/bin/python
import urllib2
import base64
import json
General scrypt settings.
Set the appropriate username and password.
Enter the id of the group that will turn on and off the timers
Enter the ids of the timers that will be turned on and off
domoticzusername = "username"
domoticzpassword = "password"
group_id = "1"
timer_ids = [1, 2]
Build the encoded password string
Process the url request
Request the group and scene list.
Filter out the status of the desired group id
set the json command based on the status
url = "http://" + domoticzserver + "/json.htm?type=scenes"
data = json.loads(DomoticzRequest(url))
group_info = [obj for obj in data["result"] if(obj["idx"]== group_id)]
group_status = group_info[0]["Status"]
if group_status == "Off":
  json_command = "/json.htm?type=command&param=disabletimer&idx="
else:
  json_command = "/json.htm?type=command&param=enabletimer&idx="
Send the json command for all desired timer ids
for id in timer_ids:
  url = "http://" + domoticzserver + json_command + "%i" %id
