Home Easy (HE876) Dimmer
Posted: Monday 07 September 2015 22:09
by smq
I bought several Home Easy HE876 dimmers and paired their with RFX Com and Domoticz.
It's working to send On command but when I trying to set some level of light - it's not working properly. Light level is going up and down unconstant without even touching.
Unfortunately for now dimmers are not usable at all ;(
Anybody has this king of problems? I'm looking for some solutions.
Thank you in advance.
Re: Home Easy (HE876) Dimmer
Posted: Tuesday 08 September 2015 12:11
by b_weijenberg
The HE878 shows the same problem. It is not possible to set these modules to a dim level.
The module will switch to a certain dim level but not the correct one and after this command the module becomes frozen for a number of commands following the set dim level.
The HomeEasy EU ON/Off and ARC On/Off operates correct. But the module becomes in a dim cycle on a 2nd On command.
Posted: Sunday 05 June 2016 23:49
by s3rgi
I have another problem with one Home Easy HE876. The pairing with Domoticz and RFlink seems to be correct. When I do the automatic search and I press the button of the remote control corresponding the HE876, domoticz creates a switch and see the status of the dimmer when I press the remote control, but when I try to send On/Off command from domoticz the dimmer do not do anything...
Posted: Wednesday 03 August 2016 12:01
by DomoB
Same problem here, is use scene's to set all my wall lighting to the same dim level but this is not possible with this dimmer....
Is there a solution or nice work around for this ?
I use the dimmer with rfxcom as: Lighting 2 HomeEasy EU device.
Posted: Sunday 09 October 2016 15:00
by Hesmink
Any update on this?
Apparently, the method of dimming for this switch is: 1. Turn lamp on. 2. Turn lamp on again, lamp starts cycling dim levels. 3. Press 'lamp on' again.
Although I'm sending dim levels, the dimmer doesn't respond to it.
Posted: Sunday 02 April 2017 13:20
by reindje
Same problem here, no one has get this work with setting dimlevel?
Posted: Sunday 24 December 2017 13:39
by edezwaan82
Hi All,
What is the ID for HE878. Unfortunately I lost my remote so I need to configure it manually.
Can anyone help?
