WiringPi library not found. GPIO support disabled
Posted: Saturday 22 August 2015 10:39
by Bikey
I juist tried to build Domoticz form source, according to the Wiki.
However after:
git clone https://github.com/domoticz/domoticz.git dev-domoticz
cd dev-domoticz
cmake -DCMAKE_BUILD_TYPE=Release CMakeLists.txt
I get the following error:
-- WiringPi include was found in /usr/local/include...
-- ==== WiringPi library not found. GPIO support disabled.
-- ==== (Please follow http://wiringpi.com/download-and-install/ if you want to use GPIO.)
/usr/bin/c++ -DPCHCOMPILE -O3;-DNDEBUG;-I/home/pi/dev-domoticz/main;-I/usr/include;-I/usr/include;;-DNS_ENABLE_SSL;-DWITH_LIBUSB;-DNS_ENABLE_SSL -x c++-header -o /home/pi/dev-domoticz/stdafx.h.gch/.c++ /home/pi/dev-domoticz/main/stdafx.h
Further building works fine (after resolving from the "undefined reference to symbol 'clock_gettime@@GLIBC_2.4" error as discussed in this topic) but the resulting Domoticz installation does not support the GPIO hardware, as expected.
I have installed WiringPi (according to the link. Directory is placed at /home/pi/wiringPi) and everything works fine with the latest beta 2.2765, so only the building fails.
I'm not a programmer, just following instructions, so what can I do to include the correct libraries? Can you change the CMakeList.txt on GitHub?
Re: WiringPi library not found. GPIO support disabled
Posted: Saturday 22 August 2015 11:48
by gizmocuz
This is just a warning, and there is no need to change the cmake script
did you try
cd wiringPi
make static
sudo make install-static
and then build ?
Posted: Saturday 22 August 2015 17:00
by Bikey
That helped, I now could build everything and GPIO is working. Thanks, Gizmocuz!
Posted: Monday 14 September 2015 9:48
by stamppot
gizmocuz wrote: cd wiringPi
make static
Actually I ran into the very same thing. Is there a reason why domoticz is linking against the static version of wiringPi? Especially as it doesn´t get installed by default. If there is no good reason, can I suggest to link against the dynamic library? If there is a good reason, it might be a good idea to update the CMakeLists.txt output to indicate that this is the problem. In both cases I can submit a patch... :-)
BR,
Sander
Posted: Monday 05 October 2015 1:03
by ViperScull
stamppot wrote: Actually I ran into the very same thing. Is there a reason why domoticz is linking against the static version of wiringPi? Especially as it doesn´t get installed by default. If there is no good reason, can I suggest to link against the dynamic library? If there is a good reason, it might be a good idea to update the CMakeLists.txt output to indicate that this is the problem. In both cases I can submit a patch... :-)
BR,
Sander
I'm finding the same installing in Arch Linux. If you could post a patch a here, that'd be great.
Posted: Monday 18 April 2016 13:31
by ced216
gizmocuz wrote:This is just a warning, and there is no need to change the cmake script
did you try
cd wiringPi
make static
and then build ?
I need some help, I have this message
make: *** No rule to make target 'static'. Arrêt.
Posted: Monday 18 April 2016 18:58
by bobkersten
There's a "wiringPi" folder within the "wiringPi" folder that you'll have to "cd" into, so those commands from gizmocuz, including the "cd wiringPi", need to be run from within the main wiringPi folder :)
Posted: Wednesday 20 April 2016 6:41
by ced216
It's ok now, I haven't seen the sub folder. Thanks !
Posted: Friday 13 January 2017 10:39
by jvandenbroek
This works as expected, might be useful to include this in the wiki page?
