Evohome - error on initial update
Posted: Saturday 15 August 2015 15:12
I tried installing the evohome client by following the instructions on:
http://www.domoticz.com/wiki/Evohome
At the step "Create the initial Domoticz hardware device and zones make sure Python and the evohome-client are installed before running this", I receive an error and nothing is being created.
pi@raspberrypi ~/evohome-client $ /home/pi/evohome-client/evo-update.sh init
/usr/local/lib/python2.7/dist-packages/requests/packages/urllib3/util/ssl_.py:90: InsecurePlatformWarning: A true SSLContext object is not available. This prevents urllib3 from configuring SSL appropriately and may cause certain SSL connections to fail. For more information, see https://urllib3.readthedocs.org/en/late ... ormwarning.
File "/home/pi/evohome-client/evo-update.sh", line 52, in <module>
r=requests.get("http://%s:%s/json.htm?type=command¶m=addhardware&htype=40&port=1&name=%s&enabled=true&datatimeout=0" % (evoconfig.url,evoconfig.port,hwname))
File "/usr/local/lib/python2.7/dist-packages/requests/api.py", line 69, in get
return request('get', url, params=params, **kwargs)
File "/usr/local/lib/python2.7/dist-packages/requests/api.py", line 50, in request
response = session.request(method=method, url=url, **kwargs)
File "/usr/local/lib/python2.7/dist-packages/requests/sessions.py", line 465, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python2.7/dist-packages/requests/sessions.py", line 573, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python2.7/dist-packages/requests/adapters.py", line 415, in send
raise ConnectionError(err, request=request)
requests.exceptions.ConnectionError: ('Connection aborted.', error(111, 'Connection refused'))
Does anyone know what I need to do to solve this?
