PIR-sensor/bewegingsmelder Home Security Aliexpress
Posted: Sunday 09 August 2015 8:29
by kvanhoorn
Does anyone have experience with these sensors?
http://nl.aliexpress.com/item/Free-Ship ... 77500.html
I contacted the supplier a couple of times, but their English is that bad that I'm not able to communicate with them.
So, anyone any good experience with Domoticz and the cheap motion sensors?
Kind regards
Re: PIR-sensor/bewegingsmelder Home Security Aliexpress
Posted: Sunday 09 August 2015 10:19
by ThinkPad
They will work, see this topic:
http://domoticz.com/forum/viewtopic.php ... 262#p32296
Be sure to get the 4333Mhz version, not the 315Mhz.
But be aware of the fact that those PIR's only send a on signal, so you will need a 'off delay' in Domoticz.
And they also seem to use quite a bit of power, resulting in empty battery quite fast:
http://domoticz.com/forum/viewtopic.php ... 180#p50660
Posted: Sunday 09 August 2015 10:23
by kvanhoorn
@ThinkPad I saw that topic earlier, but wasn't shure if the PIR motion detectors were compatible too. Do I also need to change some jumpers or alter the chip or is it plug and play?
Posted: Sunday 09 August 2015 10:27
by kvanhoorn
Maybe I should start with two just in case. 433 Mhz Home Alarm System Wireless PIR Sensor / Motion Detector - 2 Pack
http://www.aliexpress.com/item/433mhz-h ... 30901.html are these the same protocol?
Posted: Sunday 09 August 2015 11:09
by ThinkPad
If you get one with a PT2262 or SC2262 chip, it will work with RFXCOM. But you can only be sure if it is mentioned in the product description. Hard to tell from only a picture of the complete unit
Best to see if you can find a link from the topic i mentioned, and order them from that seller.
Posted: Sunday 28 February 2016 19:08
by jarwis
I've bought
433MHZ Wireless PIR Motion Detector for Home Alarm Home Security from Banggood.
http://www.banggood.com/433MHZ-Wireless ... 52710.html
Package:
https://goo.gl/photos/pvKBphXmjffr4ZL57
Opened, circuit visible:
https://goo.gl/photos/gYpsP2EqyEkfgVrJ9
Circuit, front side:
https://goo.gl/photos/pYF7HHStXpjnesuRA
Circuit, back side:
https://goo.gl/photos/nSDb72dU3s14U7QG9
PROs:
- Cheap, 10,94 euros
- Works with RFXtrx433E and Domoticz
- Jumper for setting LED off
- Possibility to set alarm delay (5 sec, 50 sec or 5 min)
- The package includes 10 spare jumpers
CONS:
- Long delivery time (48 days to Finland)
- Sends only ON command (need to use OFF delay)
- Instructions don't explain Code Jumper settings
- Difficult installation
I had no idea how to set Code Jumpers so I copied to settings from here:
http://domoticz.com/forum/viewtopic.php ... =40#p17076
The above jumpers settings show up in Domoticz as:
25 RFXtrx433E FF5515 0 Liiketunnistin Lighting 4 PT2262 Off 7
Lighting4 protocol must be enabled in RFXtrx433E.
Posted: Saturday 05 March 2016 21:41
by jmleglise
This 433.92Mhz wireless motion sensor works fine with RFXCOM RFXTRXE as Lighting4
PT2262 chip
Battery Type: DC 9V
External Power Supply: DC12V
9meter detection
(model AFT-701)
http://www.aliexpress.com/item/433-MHz- ... 18695.html
Posted: Thursday 09 August 2018 18:02
by Lucmaas
My PIR sensor wont be detected by domoticz is this one supported? I got an RFXCOM - RFXtrx433
Alie link: (
https://nl.aliexpress.com/item/Free-Shi ... 4c4dTvHRDG)
Posted: Thursday 09 August 2018 18:03
by Lucmaas
Yes I already tried extending the antenna.
Posted: Thursday 09 August 2018 19:21
by b_weijenberg
Check with only Lighting4 enabled.
If it does not operate contact rfxcom.com
Posted: Thursday 09 August 2018 20:03
by Lucmaas
b_weijenberg wrote: Thursday 09 August 2018 19:21
Thanks Worked now
