using a 3 clamp CM180i for circuit + house
Posted: Saturday 08 August 2015 16:05
the CM180i has 3 clamps and can report 3 circuits. But it sums the total in domoticz thus gives incorrect electricity consumption values.
I've made a simple script that is triggered each time the sensors sends up values, I extract clamp 3 which is the whole house and push it in a virtual device.
I need help understanding the second value of the device this way, is that usage value + last usage or something else ?
edit: I've progressed a bit to get the two devices I needed to follow instant usage and money usage
function timedifference(s)
year = string.sub(s, 1, 4)
month = string.sub(s, 6, 7)
day = string.sub(s, 9, 10)
hour = string.sub(s, 12, 13)
t1 = os.time()
return difference
function timeCount(numSec)
local nSeconds = numSec
if nSeconds == 0 then
return "0seconds"
local sTime = ""
local nHours = math.floor(nSeconds/3600)
local nMins = math.floor(nSeconds/60 - (nHours*60))
if(nHours > 0) then
sTime = sTime .. nHours
if(nHours == 1) then
sTime = sTime .. "hour "
sTime = sTime .. "hours "
if(nMins > 0) then
sTime = sTime .. nMins
if(nMins == 1) then
sTime = sTime .. "minute "
sTime = sTime .. "minutes "
local nSecs = math.floor(nSeconds - nHours*3600 - nMins *60)
if(nSecs > 0) then
sTime = sTime .. nSecs
if(nSecs == 1) then
sTime = sTime .. "second"
sTime = sTime .. "seconds"
return sTime
Counter1='CM180i-1 etage/frigo-four/general' -- your physical CM180i multi device
Counter2='ERGY Elec' --your virtual device name
usageid2=384 --your virtual curve only device id
Counter3='ERGY Elec total' --your virtual device name
usageid3=385 --your virtual total device id
voltage=240 --your voltage
if (devicechanged[Counter1]) then
--456 Watt, 120 Watt, 552 Watt, Total: 5082364.830 Wh
--T=1.9;0.8;2.6;5082606.047
l1, l2, l3, tot = otherdevices_svalues[Counter1]:match("([^;]+);([^;]+);([^;]+);([^;]+)")
c1, c2 = otherdevices_svalues[Counter3]:match("([^;]+);([^;]+)")
interval = timedifference(otherdevices_lastupdate[Counter1])
-- convert internal in seconds into hours
interval = interval / 3600
wattage=l3*voltage
t_wattage=c2+wattage*interval
commandArray[1]={['UpdateDevice']= usageid2 .. "|0|" .. wattage }
commandArray[2]={['UpdateDevice']= usageid3 .. "|0|" .. wattage .. ";" .. t_wattage}
