Script -Error - Returned: 256
Posted: Thursday 30 July 2015 23:33
by vicenschamorro
Hi All,
I'm a novice in Domoticz. I've configured correctly a couple of ZWave devices. The problem I have is that I cannot execute scripts in a Raspberry Pi 2 environment.
I've read a lot about this topic in the forums and internet but I have not be able to find a solution.
All the attempts has been unsuccessful. Always the error I see in the log from Domoticz is the same:
"Error: Error executing script command (/home/pi/domoticz/scripts/play_radio_sonos.py). returned: 256"
I've tried:
1. Add 777 permisions to the script file
2. Reboot pi and domoticz
3. Add a third "/" in the domoticz - On Action
4. Write the script in bash or python
5. Move the script to another locations
and probably other scenarios that now I cannot remember.
One important point is that if I execute the script using the "pi" user, I don't have any problem.
Any idea?
Thanks!!!
Vicens
Re: Script -Error - Returned: 256
Posted: Monday 03 August 2015 11:41
by vicenschamorro
I've been all the weekend trying alternatives without any progress.... Do you have some idea?
Posted: Wednesday 05 August 2015 21:53
by zaadstra
Today I've been debugging this "feature" for the second time.
First case, I ran a script with parameters, and one parameter was incorrect and the script wasn't too happy about that. The commandline showed that quickly.
Today, another script was tested on commandline first and happily ran there, but not as Action in Domoticz. This time it appeared that a config file was not used/not found but no clear error given.
2015-08-05 21:33:02.885 Error: Error executing script command (/home/pi/pushover/pushover.sh). returned: 256
2015-08-05 21:43:51.274 Error: Error executing script command (/home/pi/domoticz/scripts/pushover.sh). returned: 256
The problem was solved when I added extra parameters to the script line (the ones it should read from it's file in /home/pi/.config/
So tweak a little with your script and/or parameters, good luck
Posted: Friday 25 September 2015 21:29
by oliviers
Like several others, I'm also unable to execute scrits from an On/off virtual swith.... They result in "errror 256"..
2015-09-25 21:09:04.325 Executing script: /home/pi/domoticz/scripts/listen_radio.sh
2015-09-25 21:09:43.315 Error: Error executing script command (/home/pi/domoticz/scripts/listen_radio.sh). returned: 256
2015-09-25 21:09:44.324 Executing script: /home/pi/domoticz/scripts/stop_radio.sh
2015-09-25 21:09:45.064 Error: Error executing script command (/home/pi/domoticz/scripts/stop_radio.sh). returned: 256
Both scripts run just fine when executed from the command line.
Both scripts are owned by "pi" and have proper execution flags:
pi@raspberrypi ~/domoticz/scripts $ ls -l *radio*
-rwxrwxrwx 1 pi pi 103 Sep 25 17:06 listen_radio.sh
-rwxr-xr-x 1 pi pi 59 Sep 25 18:06 stop_radio.sh
I have tried with two or three '/' in the swith configuration:
script:///home/pi/domoticz/scripts/listen_radio.sh
script:///home/pi/domoticz/scripts/stop_radio.sh
Script contents are quite simple:
pi@raspberrypi ~/domoticz/scripts $ cat listen_*
#!/bin/bash
echo RADIO CLASSIQUE
mplayer -noconsolecontrols -playlist /home/pi/domoticz/playlist.txt
and
pi@raspberrypi ~/domoticz/scripts $ cat stop*
#!/bin/bash
sudo /usr/bin/killall mplayer > /dev/nul
Anyone has an idea ?
Oliviers
EDIT:
This is solved.
1. If any command in the script sends messages to the console, make sure you redirect the output somewhere ( > /dev/null)
(In my example above, this is the case of the mplayer command)
2. If any command "never ends/never returns" (like the mplayer radio streaming in my case), put an "&" at the end of the command to let the script continue and finish
Posted: Friday 21 October 2016 22:28
by jpinzon408
Hi, for ON/OFF works for me this way,
for ON: script:///path/yourpythonprogramON.sh
#!/bin/sh
python yourpythonprogram.py > /dev/null 2>&1 &
exit 0
and OFF: only script:///path/yourpythonprogramOFF.py
I hope you find this information useful.
Posted: Sunday 27 November 2016 1:33
by Larka
zaadstra wrote:Today I've been debugging this "feature" for the second time.
I thought I would post my findings from when I had the same problem. Since my domoticz run as root, the scripts were executed as root as well. So in my case it tried to find the config files in /root/.config/xxx and then failed
Maybe someone will find this useful.
Posted: Tuesday 28 March 2017 13:01
by MikeNg
Got the same issue with the playcode.py script running from on/off action of a domoticz switch. Checked in the log it say error executing script returned 256. Running the script from SSH comand line it works perfectly.
Posted: Saturday 29 July 2017 19:58
by Stefan
I`m also facing issues with this. My switch triggers two scripts, on and off. It throws the error 256 on both on and off action, however the on does get executed and turns on the purifier. I can`t understand why, since the scripts look exactly the same, both are owned by root and permission 777 had been applied.
ON:
#!/usr/bin/lua
if (devicechanged['Air Purifier'] == 'On') then
os.execute ('node /etc/domoticz/scripts/xiaomi/airpurifier.js 192.168.1.20 power true > /dev/null')
OFF:
#!/usr/bin/lua
if (devicechanged['Air Purifier'] == 'Off') then
os.execute ('node /etc/domoticz/scripts/xiaomi/airpurifier.js 192.168.1.20 power false')
root@stf-pi:/etc/domoticz/scripts/xiaomi# pwd
root@stf-pi:/etc/domoticz/scripts/xiaomi# ls
airpurifier.js air_purifier_off.lua air_purifier_on.lua
2017-07-29 19:36:22.376 Error: Error executing script command (/etc/domoticz/scripts/xiaomi/air_purifier_on.lua). returned: 256
2017-07-29 19:36:32.979 Error: Error executing script command (/etc/domoticz/scripts/xiaomi/air_purifier_off.lua). returned: 256
2017-07-29 19:39:17.320 Error: Error executing script command (/etc/domoticz/scripts/xiaomi/air_purifier_on.lua). returned: 256
2017-07-29 19:39:27.036 Error: Error executing script command (/etc/domoticz/scripts/xiaomi/air_purifier_off.lua). returned: 256
2017-07-29 19:41:07.420 Error: Error executing script command (/etc/domoticz/scripts/xiaomi/air_purifier_on.lua). returned: 256
2017-07-29 19:41:15.853 Error: Error executing script command (/etc/domoticz/scripts/xiaomi/air_purifier_off.lua). returned: 256
- fan.JPG (44.71 KiB) Viewed 15620 times
Can somebody help pls?
Posted: Saturday 29 July 2017 21:04
by oliviers
The answer is above in this thread. You need an "intermediate" script which launches your lua sript with an "&" at the end of the command line to return to Domoticz without waiting. See my post of Sept 16 2015 and the post from jpinzon408 dated 21 Oct 2016.
Rgds,
Oliviers
Posted: Thursday 13 June 2019 18:42
by EdddieN
Hello
Reviving this.
I'm doing a simple pmrestart.sh
#!/bin/sh
/usr/bin/pm2 restart all
my pmrestart.sh has a 755 and works from shell. But when I try to execute it within Domoticz I get the 256 error on the log file.
I have other SH files that work fine no idea why I'm wrong here. Any help?
Posted: Friday 27 December 2019 19:40
by timmpo
old thread but ...
When one of this problem hit me, was it because my python library environment path not was set when run from root/sudo
domoticz run python scripts with sudo/root environment path's
Stop Domoticz service:
Run Domoticz direct from terminal:
Run the script from inside domoticz (pushbutton etc..)
now you shuld see in terminal what cuase the problem
- pic.png (60.78 KiB) Viewed 8891 times
you can run this python code to check your environment path's the user using
- pic2.png (29.07 KiB) Viewed 8891 times
for me sudoers missing /home/pi/.local/lib/python2.7/site-packages
to fix that you can add this directly in your python code
import sys
sys.path.append('/home/pi/.local/lib/python2.7/site-packages')
Posted: Wednesday 02 December 2020 23:45
by Keptenkurk
old thread but...
timmpo, thanks for sharing your solution, it saved my day! (after all other fixes about rights, wrapping the python script in a bash shell etc failed).
My newly installed and imported lib was just not in the path...
/paul
Posted: Wednesday 23 December 2020 11:41
by damdub
Hello all,
I read and followed solutions provided here with no luck.
I have a .sh script which I fire from a switch in domoticz.
The script is supposed to change a switch configuration via telnet communication.
The script is working from console with no error.
The script is working from Domoticz but leaves an error in logs
Error executing script command (/home/pi/domoticz/scripts/remote_HP_switch.sh). returned: 256
The script is
#!/bin/sh
HOST='***.***.***.***' /IP address of the switch
CMD1='conf'
CMD2='interface 1 enable"
echo open "$HOST"
sleep 0.2
echo "$x"
sleep 0.2
echo "$CMD1"
sleep 0.2
echo "$CMD2"
sleep 0.2
echo "exit"
) | telnet
The script file permissions is rwx for everyone
I could live with the error as the script is running OK but I would prefer to understand what I'm doing wrong
Any idea someone ?
Thank you very much
Damien
Posted: Wednesday 23 December 2020 13:43
by FireWizard
Hi, @damdub
Please, have a look at:
viewtopic.php?f=6&t=30657&p=231907#p231907
Perhaps the solution at the end, mentioned by DewGew is also suitable for you.
Best regards
Posted: Wednesday 23 December 2020 15:23
by damdub
Hello FireWizard
Thank you for taking care of this case
I haven't tried your suggestion yet but are you sure it could change something for me ? I doubt that because in my case the script runs and does what I want him to do. The command reaches my HP switch and the configuration is changed as asked in the script. But there is an error code 256 in the domoticz logs.
Damien
Posted: Wednesday 23 December 2020 16:01
by damdub
Hello
I've found the solution.
I had to close the telnet communication properly at the end of the script by adding a exit 0
For anyone interrested in scripting HP Switch config, my working script is now
#!/bin/sh
CMD1='conf'
echo open "$HOST"
sleep 0.2
echo "$x"
sleep 0.2
echo "$CMD1"
sleep 0.2
echo "$CMD2"
) | telnet > /dev/null
exit 0
Thank you for your help
Damien
Posted: Saturday 16 January 2021 21:16
by OldPensionado
@timmpo: many thanks! Your solution about an incomplete PATH variable saved my weekend!
Especially the suggestion about running Domoticz from the terminal and then printing sys.path was extremely clarifying.
Thanks again!
(And yes, I know: it's an old thread but who cares! I'm old too...)
Posted: Friday 14 October 2022 11:56
by nigels0
A good check before doing anything is to run the script with sudo beforehand. It should give an idea where the problems are.
I found that with my python scripts, I needed to install a library again using sudo pip install <libraryname> - saves having to edit the path.
