ZWAVE DOUBLE SWITCH
Posted: Tuesday 28 July 2015 14:58
by kopite
I have added a double inwall switch to my domoticz system (RPi with Razberry) but it only shows up as a single switch.
In the openzwave control pannel it shows as "Schlage Link Unknown: type=1122, id=5501" and has all 3 "switch All" set to disabled??
Anyone able to point me in the right direction?
Re: ZWAVE DOUBLE SWITCH
Posted: Tuesday 28 July 2015 17:29
by pvm
Which brand/type? I use a fibaro 2x 1,5is with aeon stick
Posted: Wednesday 29 July 2015 3:51
by kopite
It is a digaL home systems
DHS-ZW-SWIW-01
Posted: Wednesday 29 July 2015 16:38
by xs4me
To be clear you are using Razberry aka z-way. Not openzwave?
In that case your out of luck since z-way does not support MultiChannel. Switch to OpenZwave which does support MultiChannel.
Posted: Saturday 08 August 2015 9:44
by kopite
@xs4me what do you mean by switch to openzwave? I thought openzwave was running under Domoticz?
Posted: Saturday 08 August 2015 10:18
by xs4me
Well Domoticz support two different ZWave implementations, Razberry Z-Wave via LAN interface and OpenZWave via USB.
The first one is via Rasberry with a Z-Wave addon board(z-way). The second is via a Z-Wave USB dongle like Aeotec Z-Stick-S2 or Vision ZU1401 USB stick.
So witch one are you using?
Posted: Saturday 08 August 2015 10:43
by kopite
I am using Razberry......is there any way of using Razberry without Z-Way?
Posted: Saturday 08 August 2015 10:54
by xs4me
I don't think so, but since I don't own one I am no expert
Posted: Saturday 08 August 2015 23:17
by kopite
Thanks @xs4me
Anyone know the answer?
Posted: Sunday 09 August 2015 1:41
by kopite
Actually @xs4me, i followed
http://www.vesternet.com/resources/appl ... _4xlxYU58E and configured the board to use openzwave
Posted: Sunday 09 August 2015 11:16
by xs4me
Oke good!. Have you tried to excluding and re-including the device already? You can also remove your node from the zwcfg_0x???.xml file and restart domoticz.
Posted: Monday 10 August 2015 1:35
by kopite
I have tried inclusion exclusion but not removing it from zwcfg_0xxxx.xml
Posted: Thursday 03 March 2016 6:11
by Duc998
anyone have any updates on this? Mine works fine. Just comes up as unknown. No parameters available.
The only issue I've had with this switch is when I'm shutdown the power for the house this switch becomes dead then I have to exclude/include.
Posted: Thursday 03 March 2016 9:02
by gizmocuz
Duc998 wrote:anyone have any updates on this? Mine works fine. Just comes up as unknown. No parameters available.
You have to check the file manufacturer_specific.xml in the Config folder
If your switch is now supported, you need to either exclude/include again, or delete the zwcfg_xxxx.xml file in the config folder,
but then you have to send all node-information-frames again from all your other zwave devices (press the button)
If it is not inside the manufactorer file (product id/type), then you will have to add support for this.
sometimes hardware can have multiple product id's and types, and you can use this.
But all has to be done for openzwave, best to go to the openzwave website for this
