Samsung SNH-P6410BN
mcduarte2000
Samsung SNH-P6410BN
Post by mcduarte2000 »
I've a Samsung SNH-P6410BN. The jpg url is not documented but through google I could find the snapshot URL:
http://192.168.1.xxx/cgi-bin/video.cgi?msubmenu=jpg&resolution=xx
(resolution can be 1 to 10, I tried different values without success)
It works in the browser (requests user and password), and works in the preview/test of Domoticz (I can see it live in the test screen). But then, it doesn't work after the camera is added.
Any ideas? A possible bug in Domoticz (if it works in test I guess it should also work on the application)?
Thanks,
Miguel
Warlock00
Domoticz version: 2.4768
Re: Samsung SNH-P6410BN
Post by Warlock00 »
Why no reply to this?
I have the same problem. Works in edit / test connection screen only.
Samsung snv-l6083r
http://192.168.3.122/cgi-bin/video.cgi?msubmenu=jpg
IP Address: 192.168.3.122
Port: 80
Image URL: /cgi-bin/video.cgi?msubmenu=jpg
Running Domoticz V2.4768 on Synology NAS
martk
Post by martk »
I found out that the Samsung camera's do have an RTSP stream. You can use this stream to get a snapshot. I've got it working here on 2 camera's :))
You'll have to install ffmpeg, google how to install that on Jessie. After that you can use this bash script for instance to send a snapshot using a Telegram bot:
#!/bin/sh
export DATETIME=`date +%Y%m%d%H%M%S`
ffmpeg -i rtsp://admin:[email protected]/profile5/media.smp -vframes 1 -r 1 /home/pi/domoticz/www/snapshots/cam1/$DATETIME.jpg
#Verstuur de foto met Telegram
curl -s -X POST "https://api.telegram.org/botblablacode/sendPhoto" -F chat_id=@CHATID -F photo="@/home/pi/domoticz/www/snapshots/cam1/$DATETIME.jpg"
#Verstuur bericht beweging gedetecteerd!
curl --data chat_id=@CHATID --data-urlencode "text=Beweging op buitencamera gedetecteerd!"  "https://api.telegram.org/bot200094474:AAHAEyCcGcfbnHOzP8nmxgsjF313CQ6jWac/sendMessage"
#Delete previous taken snapshots older than 7 days
find /home/pi/domoticz/www/snapshots/cam1/ -name '*.jpeg' -mtime +7 -delete
I'll run this bash script using a lua script :)
