Add a refresh cache button Topic is solved
- leecollings
Would it be an easy task to add an 'Clear Cache' button to the Setup dropdown menu?
- gizmocuz
Re: Add a refresh cache button
that is a browser issue, you can only perform this in the browser
Why would you need this? If you are developing, then add a startup parameter -nocache
- leecollings
How exactly can this be done? What files need to be edited?gizmocuz wrote:If you are developing, then add a startup parameter -nocache
RidingTheFlow
I use option on Chrome which temporarily disables cache when development panel (Ctrl-Shift-I) is up. Works pretty well.
- bizziebis
- Domoticz version: 3.8805
Or open a new 'Private browsing' tab. This should be something everyone should try when they think they have troubles with Domoticz web interface. Very easy, very efficient.
- Marci
- Domoticz version: 3.8153
On raspberry...leecollings wrote:How exactly can this be done? What files need to be edited?gizmocuz wrote:If you are developing, then add a startup parameter -nocache
sudo service domoticz.sh stop
cd ~/domoticz
./domoticz -nocacheWhen done developing... Ctrl-C to stop Domoticz... then
sudo service domoticz.sh start...to go back to normal running, and switch back to regular browser window.
