Has anyone has success with Zoneminder and Domoticz?
Posted: Tuesday 07 July 2015 23:14
by resentedpoet
Has anyone had any success with Zoneminder and Domoticz? I have Zoneminder set up and working fine on my server and can see the streams in my browser no problem from another PC. I wanted to then integrate it into Domoticz, but I can't for some reason get the streams to work. Not sure what I am doing wrong here, was hoping someone could point me in the right direction.
Thanks,
Re: Has anyone has success with Zoneminder and Domoticz?
Posted: Wednesday 08 July 2015 10:24
by ThinkPad
As far as i know Domoticz only supports a JPEG/MJPEG stream. So have a look at the streams that Zoneminder spits out.
By the way, you don't happen to have Synology NAS? Otherwise you could add the cams there and use this script i made:
http://domoticz.com/forum/viewtopic.php?f=23&t=6794
Posted: Thursday 09 July 2015 10:14
by resentedpoet
Hi Thinkpad,
Ok, didn't know about the limitations, thanks for the info. I've been trying any and all the suggestions from
http://www.ispyconnect.com/man.aspx?n=Zoneminder but still no luck.
Posted: Saturday 26 March 2016 15:09
by Blipvert
I use the following imageURL to get my Zoneminder cameras (3 mpeg and 1 rtsp) into Domoticz:
<zoneminder_folder>/cgi-bin/zms?mode=single&monitor=<monitor_number>&
So, for example, if your Zoneminder web page is accessed via
http://192.168.1.23:8080/zm and you want to get your camera 1 (monitor 1 in Zoneminder) configured in Domoticz, the Domoticz config would be:
Name: <name you wish for the camera>
IP Address: 192.168.1.23
Port: 8080
Username: <the username you use to access Zoneminder; blank if none>
Password: <the password you use for the username above; blank if none>
imageURL: zm/cgi-bin/zms?mode=single&monitor=1&
The version of ZoneminderI use is 1.29, and my Domoticz is v.3.4834 on a Raspberry Pi.
Posted: Tuesday 31 May 2016 16:54
by hasan
Blipvert wrote:I use the following imageURL to get my Zoneminder cameras (3 mpeg and 1 rtsp) into Domoticz:
Port: 8080
Hi Blipvert,
I follow your instruction but DOMOTICZ doesn't show anything. Zoneminder shows picture from cameras well. Do you have any ideas why?
Posted: Wednesday 15 June 2016 20:58
by Blipvert
What is the exact URL that you use to access your Zoneminder? (mask the IP)
Posted: Thursday 16 June 2016 11:28
by hasan
Blipvert wrote:I follow your instruction but DOMOTICZ doesn't show anything. Zoneminder shows picture from cameras well. Do you have any ideas why?
http://192.168.4.111/zm
Posted: Thursday 16 June 2016 20:10
by Blipvert
Then your configuration should be:
Name: <name you wish for the camera on Domoticz>
IP Address: 192.168.4.111
Port: 80
Username:
Password:
That is, for as long as the camera that you want to access is the monitor 1 in Zoneminder; try increasing the number if you have more than one camera configured on Zoneminder.
For a test, you can try to access this url:
http://192.168.4.111/zm/cgi-bin/zms?mod ... &monitor=1
(again, change the monitor number to fit your needs)
If this does not show you an image, then there is something missing on your Zoneminder config.
Posted: Friday 17 June 2016 13:38
by hasan
Port: 80
Username:
Password:
This was exactly what I tried
so I'll check ZM configuration
Posted: Friday 17 June 2016 22:13
by Blipvert
Posted: Thursday 26 January 2017 9:34
by hasan
I installed everything from scratch and it is working now. Thanks for help...
Posted: Saturday 11 November 2017 19:54
by woody4165
Just discovered zoneminder and it's really nice
Is there any possibility to get notified in domoticz when a motion is detected?
Posted: Friday 07 September 2018 9:27
by Trigun
hi there,
i know this is an old threat but i am hoping someone can help me out here.
I have zoneminder configured and working well(v1.30.4).
I would like to enable the zoneminder stream into domoticz.
I've read the posts but can't seem to get it to work.
thanks in advance!
Grtz
Posted: Monday 10 September 2018 9:45
by Trigun
got it working.
the username and password is still tough though but without it, it working fine.
thnx!
Posted: Sunday 30 September 2018 22:10
by jannnfe
woody4165 wrote: Saturday 11 November 2017 19:54
Have a look at my modification of zmeventserver here:
https://github.com/jannnfe/zmeventserverDomoticz
