Mydlink
Posted: Thursday 25 June 2015 13:02
by Varazir
I wounder if I can control a Home WiFi Smart Plug (DSP-W215) from my domoticz
And if I can connect a DCS-935L ?
TIA
Daniel
Re: Mydlink
Posted: Friday 20 November 2015 21:29
by berkens
Somebody tried it for you and me:
viewtopic.php?f=17&t=6073#p39537
It is not possible due to the encryption using it in Domoticz.
Grtn Ben...
Re: Mydlink
Posted: Thursday 13 October 2016 20:06
by todip
Re: Mydlink
Posted: Saturday 14 January 2017 10:23
by korniza
It is working!
I suppose there is no way to control the on/off from domoticz. They are a cheap (crappy sometimes) way to control some plugs. I have 3 plugs and I suppose there are a lot of mates that did wrong on start and bought these starter kits from Dlink.
Hope for developers engagement and include D-link products to Domoticz.
Re: Mydlink
Posted: Saturday 14 January 2017 11:08
by korniza
looking around I found that also D-Link motion sensor DCH-150 uses the same protocol.
I do not know what can be the usage on polling a motion sensor but I like to add it on the common knowledge.
Re: Mydlink
Posted: Saturday 14 January 2017 12:18
by korniza
Very productive day!
I used the following script to power on/off DSP-W215 plug!!!
Responding is amazing as it is not using IFTTT. Firmware on the plug is the latest (2.22), so I need others owners to confirm that is working to other firmware versions.
https://github.com/nodeofgithub/DSP-W21 ... r/power.py
You need to provide the ip / pin (can be found on the back of plug) / and the command (on/off).
So we have the power consumption/temperature and the control. What is next?
Re: Mydlink
Posted: Saturday 14 January 2017 12:44
by korniza
We can read also the plug power status from a fork of first github repo
https://github.com/Bananis/dsp-w215-hnap/tree/patch-1 using a different app.js, which reports if plug is powered on. the hard is that the change on Domoticz will take some seconds to updated.
https://github.com/Bananis/dsp-w215-hna ... h-1/app.js
Re: Mydlink
Posted: Saturday 14 January 2017 18:34
by korniza
Developer request:
Can you build/add a entry on beta of domoticz for DSP-W215 plug? It is a 40 Euros plug with IFTTT integration. I can provide a donation for that.
Re: Mydlink
Posted: Wednesday 25 January 2017 12:52
by jelleeelco
thank you so much for your work! I have these plugs, and I'm trying to use your script to get the on/off done. However, I can't work it out!
I have the script in /domoticz/scripts/python and called them OFF.py and ON.py. I made the script executable via chmod +x. When I run ./ON.py from the command line, it gives me multiple errors ("import: command not found"), pin: command not found, etc.
So I'm doing something wrong
Did you add anything to the script other then what is on Github? I simply copied your code, made the ON.py script, made a dummy switch in Domoticz and used the ON.py and OFF.py for switching... but no luck.
Any direction or help would be GREATLY appreciated!!
Cheers
Jelle
Re: Mydlink
Posted: Wednesday 25 January 2017 14:26
by jelleeelco
I think I got it to work more or less... stupid error! My findings,please correct me if I'm wromg:
- the commands have to be low capital, so 'on' and not 'ON'.
- when copying your code as-is, it doesn't work. I have to add the following at the start of the script: #!/usr/bin/python
- it doesn't run with the IPaddress, pincode and command from in the script. If I use SSH and run the script, it tells me:
USAGE: ./ON.py <ipadress> <pin> <off>
- If i then do that in SSH, so:
./ON.py '192.168.1.31' '890789' 'on'
and the light switches on! And off if I choose 'off' of course.
So I'll create a .sh script, and in that script just execute the above SSH line.
Is this the way your code is intented? Or am I completely missing the point!?
Thanks!!
Jelle
Re: Mydlink
Posted: Wednesday 25 January 2017 14:47
by jelleeelco
ah, update. Got it to work.
- Create script with your code and add #!/usr/bin/python to the top.
- In Domoticz, create dummy switch (first create dummy hardware if you don't have on yet)
- To turn it on: script://python/power.py '192.168.1.31' '890765' 'on'
- to turn it off: script://python/power.py '192.168.1.31' '890765' 'off'
Were the IP address is the IP address of the Dlink Plug (duh..but I got it wrong at first!) and the number is your pin.
Now going to look at your status code. Many thanks so far, you have made a huge contribution!! I'm a complete idiot when it comes to coding so depend on people like you to make this happen.
Re: Mydlink
Posted: Saturday 28 January 2017 22:09
by korniza
great news guys!
We need to thank Dnpwwo for his great work!
Now you can put the file you will find on the link and put it under the folder plugin/DSP-W215 (you have to create the folder first). After that restart domoticz. Go to Hardware and add new device searching for Dlink smart plug DSP-W215!!!
Please test it are respond any issues.
http://www.domoticz.com/forum/viewtopic ... 65&t=15753
Re: Mydlink
Posted: Friday 13 April 2018 13:11
by skorpion03
Hello to all,
I have a problem with these sockets, I can safely turn them on and off via Domoticz but it is not clear how I can display in Domoticz the various data such as current consumption (W) and temperature (c).
I have read and downloaded the files at
https://github.com/bikerp/dsp-w215-hnap/wiki but it is not clear how to use the files.
I make a trivial example,
to know if the device is online I should use this string
<soap: Envelope xmlns: xsi = "
http://www.w3.org/2001/XMLSchema-instance" xmlns: xsd = "
http://www.w3.org/2001/XMLSchema" xmlns: soap = "http : //schemas.xmlsoap.org/soap/envelope/ "> <soap: Body>
<IsDeviceReady xmlns = "IP-DEVICE / HNAP1 /" /> </ soap: Body>
</ Soap: Envelope>
in the wiki we talk about HNAP_AUTH and Cookie, where these codes must be entered?
the answer I would get is:
<? xml version = "1.0" encoding = "UTF-8"?>
<IsDeviceReadyResponse xmlns = "IP-DEVICE / HNAP1 /"> <IsDeviceReadyResult> OK </ IsDeviceReadyResult> </ IsDeviceReadyResponse>
</ Soap: Body>
</ Soap: Envelope>
Where should I enter this information in Domoticz?
Is it possible to have a step by step guide? it could also be useful to others
thank you so much
