BeNext Alarm Sound: Usage of the different sounds
Posted: Thursday 25 June 2015 10:47
by SilentNL
I’m using Domoticz, and I’m really pleased about it. Keep up the good work!
But I have a question; I recently bought the BeNext Alarm Sound (
http://www.benext.eu/static/manual/alarmsound-nl.pdf). I want to setup an alarm system, with different types of alarm sounds. The BeNext Alarm Sound has six different sound types.
In Domoticz Hardware - Zwave - Setup - Benext Alarm Sound; I have the option to change the sound type:
- Domoticz Benext Alarm Sound01.png (23.55 KiB) Viewed 2599 times
And if I change the number between 1-6, and activate the BeNext Alarm switch in Domoticz, I get another sound. But how can I change this number in a script. For example with JSON? So I can create different Events in Domoticz, where I use the different sounds…
Not sure if 100% relevant; But here I found an example (They are talking about the Aeon Labs Siren, but the idea is the same) how to configure it with VERA:
http://www.vesternet.com/resources/appl ... es/apnt-90 In the chapter: “Fantastic, but I want to use the different sounds in Scenes!” But I don’t have clue how to do that in Domoticz…
Can someone help me with this?
Re: BeNext Alarm Sound: Usage of the different sounds
Posted: Monday 06 July 2015 14:18
by strebor
SilenNL, did you get any further on with your siren configuration?
I'm looking for the same information to configure the DSD31
Strebor
Posted: Monday 13 July 2015 10:22
by SilentNL
strebor wrote:SilenNL, did you get any further on with your siren configuration?
Strebor
No, unfortunately not. But here is someone else, that is also requesting a feature like this:
http://www.domoticz.com/forum/viewtopic ... 10&p=48605
Posted: Tuesday 14 July 2015 18:58
by strebor
SilentNL, such is the depth of my ignorance that I never entertained the idea that it might not be possible to programmatically change the sound settings of the siren. I would raise a tracker but I don't even have the language to ask the question. I think that without a tracker the issue is not going to be addressed by the devs.
Regards Strebor
Posted: Wednesday 29 July 2015 9:36
by SilentNL
FYI:
I requested a new feature request in the tracker. Tracker ID is: 575
Posted: Sunday 06 September 2015 12:41
by rvweert
Hey there,
While the feature hasn't been implemented you might also want to try this:
curl '
http://localhost:8080/json.htm?type=ope ... odes&idx=2'
curl '
http://localhost:8080/ozwcp/valuepost.html' --data '15-CONFIGURATION-config-byte-1-19=99' -v
15 = device index
19 = parameter
99 = value
Works for me!;-)
Cheers, Rene
Posted: Saturday 17 October 2015 19:20
by SilentNL
@ Rene: Thanks! That was the information that i needed.
I created a script (My first LUA script. I'm not familiar with the LUA script langauge) that change a setting of the BeNext Alarm device, and after that activated the BeNext Alarm device.
So I can use this in Events, and activate a different sound.
Perhaps is this script usefull for other people.
-- This script change a value of a Zwave (alarm) device. And after that it activates the Zwave (alarm) device. So it can be triggered in a Event.
-- How to:
-- Create a virtual on/off device
-- This script has to be named like the the new virtual device in the folder: ~/domoticz/scripts/lua for example "script_device_BeNext-Alarm-Sound-02.lua"
-- With the following command you can get the Zwave device information: "curl 'http://localhost:8080/json.htm?type=openzwavenodes&idx=2'"
-- (2 = The Zwave device number, that you can find Setup --> Hardware)
-- With the following command you can test a Zwave config change: "curl 'http://localhost:8080/ozwcp/valuepost.html' --data '39-CONFIGURATION-config-byte-1-7=3' -v"
-- (39 = device index, 7 = index, 3 = value you want to set)
local VirtualDevice = 'BeNext-Alarm-Sound-02' -- Name of your new Virtual Device Name.
local AlarmDevice = 'BeNext Alarm Sound' -- Name of the Zwave (alarm) device.
local nodeID = ('39') -- nodeID of the Zwave (alarm) device.
local index = ('7') -- The setting that you want to change
local clock = os.clock
function sleep(n) -- seconds
local t0 = clock()
while clock() - t0 <= n do
if (devicechanged[VirtualDevice] == 'On') then
local indexvalue = ('2') -- The value you want to set for the setting
os.execute ("curl 'http://localhost:8080/ozwcp/valuepost.html' --data '" .. nodeID .. "-CONFIGURATION-config-byte-1-" .. index .. "=" .. indexvalue .. "'&")
print("Change " .. AlarmDevice .. " parameter: " .. index .. " to " .. indexvalue)
commandArray[AlarmDevice]='On'
if (devicechanged[VirtualDevice] == 'Off') then
commandArray[AlarmDevice]='Off'
sleep(1)
local indexvalue = ('3') -- The value you want to set for the setting
Posted: Monday 23 May 2016 20:35
by juankar
Interesting question. I would like Domoticz could do so: modify parameters via script.
Any news?
