Set parameters for sleeping Z-Wave devices
Posted: Saturday 30 May 2015 9:29
by Egregius
I'm struggling to set some parameters of sleeping zwave devices.
For example: I like to deactivate the tamper sensitivity of a Fibaro FGMS001 motion sensor.
Already tried multiple times thru the OpenZwave Control Panel and also thru the domoticz hardware/zwave interface.
Seems like I can only set paramaters of the Fibaro wall plug, not for any battery powered device. And yes, I already waited several times until the wakeup time expires.
Any suggestions?
Re: Set parameters for sleeping Z-Wave devices
Posted: Saturday 30 May 2015 10:41
by gizmocuz
You could try before applying the value to wake up the node (there is a button on it somewhere), then press the apply
if it does not get it, wake it up again
Posted: Saturday 30 May 2015 10:56
by Egregius
Super, thank you!
For the Fibaro FGMS001 motion sensor it's a triple click on the button, device stays about 30 sec awake after that to receive settings.
Posted: Saturday 23 January 2016 9:37
by apetit
gizmocuz wrote:You could try before applying the value to wake up the node (there is a button on it somewhere), then press the apply
Thanks for this. In all my enthusiasm I thought the triple press was only to include the device and was getting a little grumpy with the device in sleep mode while trying the change the settings.
Posted: Thursday 26 January 2017 10:23
by bobvanoijen
I noticed the same issue and already found out that waking up the device by pushing the button indeed solves the problem.
But is there another way to change some parameters without getting a ladder to reach the button at the device attached to the ceiling of my hall?
Posted: Thursday 26 January 2017 10:26
by Egregius
Yes, wait for the wake-up time...
And don't restart zwave during that time.
Posted: Friday 03 February 2017 9:57
by bobvanoijen
Wake-up time is by default set to 21600 seconds (every 6 hours).
Is there a way to see when the last wake-up has been?
Posted: Friday 03 February 2017 15:49
by Egregius
Just wait 6 hours, grab a beer and relax ;)
