Mysensors SCT-013-030 current monitor
Posted: Friday 29 May 2015 1:12
by chatainsim
I'm working on a mysensors sensor for current monitoring.
http://forum.mysensors.org/topic/1464/s ... r-sensor/9
Domoticz see the sensors but don't add a new device.
Is it because it's not supported by Domoticz ?
If so, how can I add this new device ?
Thank you.
Regards,
Re: Mysensors SCT-013-030 current monitor
Posted: Friday 29 May 2015 7:11
by gizmocuz
maybe because you use V_VAR for sending the messages.
how about
V_WATT
V_KWH
Posted: Thursday 04 June 2015 0:16
by chatainsim
Thank you gor your answer.
It's better now, but I have another "issue".
Here is my arduino sketch :
// EmonLibrary examples openenergymonitor.org, Licence GNU GPL V3  ***/
#include <SPI.h>
#include <MySensor.h>
#include "EmonLib.h"             // Include Emon Library
EnergyMonitor emon1;             // Create an instance
#define CHILD_ID 0
MySensor gw;
unsigned long lastSend;
unsigned long SEND_FREQUENCY = 20000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
MyMessage IrmsMsg(CHILD_ID,V_WATT);
void setup()
  gw.begin();
  gw.sendSketchInfo("Energy Meter", "1.0");  // Send the sketch version information to the gateway and Controller
  gw.present(CHILD_ID, S_POWER);   // Register this device as power sensor
  emon1.current(A0, 29.0);       // Current: input pin, calibration.
void loop()
  gw.process();
  unsigned long now = millis();
  double Irms = emon1.calcIrms(1480);
  bool sendTime = now - lastSend > SEND_FREQUENCY;
  if (sendTime) {
  gw.send(IrmsMsg.set(Irms*232.0,1));
  Serial.println(Irms*232.0);
  lastSend = now;
In the serial monitor of the Arduino IDE, line Serial.println(Irms*232.0); gave me for exemple : 412.23
but in domoticz I have 0.4 watt. Is it normal or is there someting wrong in my sketch ?
And where can I find all the V_VAR supported by domoticz ? Is there a V_AMP ?
Thank you.
Posted: Monday 15 June 2015 13:49
by chatainsim
I've made some change in the Arduino code.
But there is still an issue.
I used V_WATT and V_KWH but in domoticz I've only V_KWH present, both.
#include <SPI.h>
#define CHILD_ID_WATT 0
#define CHILD_ID_KWH 1
MySensor gw;
MyMessage IrmsMsg(CHILD_ID_WATT,V_WATT);
MyMessage kWhMsg(CHILD_ID_KWH,V_KWH);
void setup()
  gw.begin();
  gw.present(CHILD_ID_WATT, S_POWER);  // Register this device as power sensor
  gw.present(CHILD_ID_KWH, S_POWER);
void loop()
  gw.process();
  //emon1.serialprint();           // Print out all variables (realpower, apparent power, Vrms, Irms, power factor)
  if (sendTime) {
    gw.send(IrmsMsg.set((Irms*232.0)*1000, 1));
//    Serial.print("Watt: ");
//    Serial.println(Irms*232.0);
    gw.send(kWhMsg.set((Irms*232.0)/1000, 1));
//    Serial.print("kWH: ");
//    Serial.println((Irms*232.0)/1000);
    lastSend = now;
Can you help me ?
Thank you.
Regards,
Posted: Tuesday 16 June 2015 16:50
by chatainsim
Anybody knows you to fixe this ?
Thank you.
Posted: Saturday 13 February 2016 19:15
by KinDR
Here is my Arduino script not 100% clear bad working for me
#include <SPI.h>
#include <Time.h>
//#define DEBUG
#define ScriptName "Energy Metter-1.3"
#define ScriptVersion "1.3"
boolean timeReceived = false , pcReceived = false , newDay = false; // start up without time
unsigned long lastUpdate = 0, lastRequest = 0 , minuten = 0;
float KWh = 0.00000 , oldKWH = 0.00000; // actualy KWH , gateway last walue of KWH
float Watt = 0.00000 , WattSum = 0.00000 ;
unsigned long samplCount = 0 , MultimetterDelay = 0 , WattDelay = 0; // maesure sample count , Volt & Amps Delay send(anti spam gtw)
MySensor gw;
#define NODE_ID 15             // fixed MySensors node ID
#define CHILD_ID_POWER 0
#define CHILD_ID_MULTIMETER 1
MyMessage voltMsg(CHILD_ID_MULTIMETER, V_VOLTAGE);
MyMessage ampMsg(CHILD_ID_MULTIMETER, V_CURRENT);
MyMessage wattMsg(CHILD_ID_POWER, V_WATT);
MyMessage kwhMsg(CHILD_ID_POWER, V_KWH);
MyMessage pcMsg(CHILD_ID_POWER, V_VAR1);
void gwWait() { //Radio wait
  gw.wait(125);
void setup() { // put your setup code here, to run once:
  gw.begin(incomingMessage, NODE_ID, false); //incomingMessage, NODE_ID, false
  gw.sendSketchInfo(ScriptName, ScriptVersion);
  gwWait();
  gw.present( CHILD_ID_POWER , S_POWER, "Watt+KWH", true);  // Register this device as power sensor
  gwWait();
  gw.present( CHILD_ID_MULTIMETER , S_MULTIMETER, "VOLTAGE+CURRENT", false);  // Register this device as multimetter sensor
  gwWait();
  //gw.send(pcMsg.set(0.0, 6));
  gw.request(CHILD_ID_POWER, V_VAR1); // Fetch last known kwh count value from gw
  gwWait();
  emon1.voltage(0, 272, 1.7);  // Voltage: input pin, calibration, phase_shift
  emon1.current(1, 29.03225); // Current: input pin, calibration. Cur Const= Ratio/BurdenR. 1800/62 = 29.
  gw.requestTime(receiveTime);
void loop() {// put your main code here, to run repeatedly:
  gw.process(); // radio process incoming message
  if ((!timeReceived && (now - lastRequest) > (10UL * 1000UL)) || (timeReceived && (now - lastRequest) > (60UL * 1000UL * 60UL))) {
   timeReceived = false;//--- 130216
   gwWait();            //--- 130216
    gw.requestTime(receiveTime);  // Request time from controller.
    lastRequest = now;
  if ((((hour() == 23) && (minute() > 55)) || (hour() == 0 && minute() < 5)) && newDay == false ) {  // if (hour() == 0 && !newDay) {
    if (timeReceived) {
      newDay = true; // set flag to new day
      oldKWH = 0;
  //    Serial.print("     _Sending:");
  //   Serial.print("        New day walue = 0:");
     // gw.send(pcMsg.set(oldKWH, 6));
  } else {
    newDay = false;
  measurePower();//measure energy...
void measurePower() {
  float Irms = emon1.calcIrms(1480);  // Calculate Irms only
  float Vrms = emon1.calcVrms(1480); // Calculate Vrms only
  if (Irms < 0.02) Irms = 0;
  if (Irms > 0.060) {
    Irms = (Irms - 0.060); //correction
  Watt = Irms * Vrms;
  WattSum +=  Watt;
  samplCount += 1;
  if (millis() - MultimetterDelay > 10000) { // send every 10 sec
    MultimetterDelay = millis();
    gw.send(voltMsg.set(Vrms, 1));  // voltage send
    gw.send(ampMsg.set(Irms, 1));  //amps send
    gwWait();
    if (!pcReceived) {//Last kwh not yet received from controller, request it again
      return;
  if (millis() - WattDelay > 60000) { // send every 60 sec
    minuten += 1;
    WattDelay = millis();
    double wattsample = WattSum / samplCount ;
//    Serial.print("     samplCount:");
//      Serial.println(samplCount);
    gw.send(wattMsg.set(wattsample, 2)); // Send watt value to gw
  if (minuten == 1 && timeReceived == true && pcReceived == true ) {
    KWh = ((WattSum / samplCount) / 1000.00 ) / 60.00;
    // Pulse count has changed
    if (oldKWH !=  KWh) {
      oldKWH +=   KWh;
   /*   Serial.print("     KWh:");
      Serial.println(KWh, 6);
      Serial.print("    oldKWH:");
      Serial.println(oldKWH, 6);    */
      if (!newDay) {
        gwWait();
    if (!newDay) {
      gw.send(kwhMsg.set(oldKWH, 6));
      minuten = 0;
      samplCount = 0;
      KWh = 0;
      WattSum = 0;
// This is called when a new time value was received
void receiveTime(unsigned long time) {
  setTime(time);   // Ok, set incoming time
  timeReceived = true;
//  Serial.println("      timeReceived:");
void incomingMessage(const MyMessage &message) {
  if (message.type == V_VAR1) {
    float gwPulseCount = message.getFloat();
//    Serial.print("      Received last value from gw:");
//    Serial.println(gwPulseCount, 6);
    oldKWH += gwPulseCount;
    pcReceived = true;
Posted: Wednesday 13 April 2016 8:55
by chatainsim
Hello all,
I tried another sketch from mysensors forum.
And only kWh is updated this time.
http://forum.mysensors.org/topic/1464/s ... -sensor/29
