Page 1 of 2
Foscam ImageUrl FI9803p v2
Posted: Tuesday 26 May 2015 7:46
by dressie
Does anyone know the ImageUrl for the Foscam FI9803P V2 with firmware 1.9.1.12/2.54.1.37. It doesn't seem to work with the usual url. I've been searching anywhere but couldn't find anything about it.
Grtz,
Andres
Re: Foscam ImageUrl FI9803p v2
Posted: Tuesday 26 May 2015 8:53
by ThinkPad
Did you already find the 'ispyconnect' website? They mention a LOT of URLs for all different brands & types of cameras.
Posted: Tuesday 26 May 2015 12:53
by dressie
Yes, I already checked but they don't have one that works either.
Posted: Tuesday 26 May 2015 16:06
by SweetPants
Tried this one?
http://<your ip>:<port>/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=username&pwd=password&
Posted: Tuesday 26 May 2015 21:10
by dressie
Nope, doesn't work either. I already have a Foscam cam working, but this type is really annoying!
Posted: Tuesday 26 May 2015 22:36
by rtna
ImageURL:
Fill in exactly as described above, so no slashes or http.
Posted: Wednesday 27 May 2015 7:55
by dressie
I tried that one already, works well for my other Foscam Cam. Looks like since the upgrade from the cam I just can't acces it anymore. Synology is able to acces it and record events, just can't seem to get the imageUrl from it. Wish I could find a way to downgrade the firmware on the cam.
Posted: Wednesday 27 May 2015 8:46
by Shaggie_NB
With an older foscam I had to change it, after updating the firmware, to:
snapshot.cgi?user=#USERNAME&pwd=#PASSWORD
it's working ok now.
Posted: Wednesday 24 June 2015 16:19
by jannl
So you got it working with the FI9803P firmware V2?
Posted: Thursday 25 June 2015 21:45
by dressie
No it's not working, no matter what I try or do. So far only Synology knows how to get an image. Hoping someone will figure it out soon!
Posted: Friday 26 June 2015 7:23
by jannl
Anybody tried to contact foscam support?
Posted: Friday 26 June 2015 8:08
by mbliek
I think you need to set the sub stream to MJPEG. See this topic: http://foscam.us/forum/how-to-fetch-sna ... t4328.html
Posted: Friday 26 June 2015 22:47
by dressie
mbliek wrote:I think you need to set the sub stream to MJPEG. See this topic: http://foscam.us/forum/how-to-fetch-sna ... t4328.html
Thanks for the tip, but I have tried all of those tricks. It must be something with the FI9803P V2 that just doesn't want me to get a stream.
Posted: Saturday 22 August 2015 21:28
by sebitop
Hi Guys
I tried to contact foscam, the URL is
http://IP : PORT/CGIProxy.fcgi?cmd=snapPicture2&usr=USER&pwd=PASSWORD
but dosen't work for me, i have exactly the same issue, syno can get the jpeg, I can see it directly on chrome but no way to get it trought domoticz it's really weird, any idea how to fix it ?
cheers
Posted: Sunday 23 August 2015 11:00
by sebitop
Guys,
I'm coming back with some good news regarding the 9803P V2 cam, here is attached a patch to apply directly to the cam (via the cam interface / apply patch) to correct the snappicture2 CGI function.
I just applied it and now the cam works perfectly on Domoticz, I can see it using the cgi command line and I can embed the image into a webpage.
I hope it will work for you too.
Cheers
FosIPC_E_patch_ver2.x.1.37_1_20150506_142201.rar
(158.84 KiB) Downloaded 545 times
Posted: Thursday 01 October 2015 9:52
by LdV46
Hi All,
I'm new to this forum as in; I never posted anything. I have used this a lot for reference and always succeeded in setting up my domoticz. Until now.. :(
I kind of have the same problem as described above. I recently bought the FI9803P V2 and now I'm trying to add it to Domoticz.
My Specs are:
Domoticz v2.2563 running on a RPi B+
Foscam FI9803P V2
Systeem Firmware Versie: 1.9.1.12
App Firmware Versie: 2.54.1.37_p1
Plug-In Versie: 3.0.0.9
Wireless connection to my network
I tried to add my cam in domoticz with the following settings:
Naam: cam1
IP Adress: http://192.168.1.50
Poort: 88
Username: [username]
Password: [password]
ImageURL: snapshot.cgi?user=[username]&pwd=[password]
But still I have no succes in adding my camera.
Did I do something wrong?
I hope to hear from you soon!
Kind Regard,
Robbert
Posted: Thursday 01 October 2015 9:58
by sebitop
read the post just above I put a patch to solve this problem
Posted: Thursday 01 October 2015 13:58
by LdV46
Hi Sebitop,
Thanks for your quick response. I already patched my cam and tried it again for good measure. Still no luck.
I tried 2 foscam usertypes (admin and visitor) and both have no result. I also tried different passwords to make sure nothing was interfering with each other.
I have tried to leave the username and password fields empty but occupied in the imageURL and vice versa, nothing happens..
I already followed the foscam instructions to set the sub stream to MJPEG.. (http://foscam.us/forum/how-to-fetch-sna ... t4328.html)
I tried cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=username&pwd=password as imageURL
I'm afraid I have overlooked something, but have no clue where..
Any help will be much apreciated!
Kind Regards,
Robbert
--- EDIT ---
I made a simple html-doc with the code below and the image was shown in the browser.. So I'm even more confused right now..
<!doctype html>
<html>
  <body>
    <canvas id='test_canvas' width='640px' height='480px' style='border:1px solid #d3d3d3'>
    </canvas>
    <script language="JavaScript">
      var ctx = document.getElementById('test_canvas').getContext('2d');
      var img = new Image();
      img.onload = function() {
        ctx.drawImage(img, 0, 0);
      var theDate = new Date();
      img.src = "http://IPADRESS:PORT/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=USERNAME&pwd=PASSWORD&";
    </script>
  </body>
</html>
Posted: Thursday 01 October 2015 19:32
by sebitop
first you must access the cam without domoticz, once it will work for sure you will have access to is on DZ
if I was you I will do the following :
- Reset the cam to factory mode
- control that the patch was correctly applied, if not reinstall it and control
- once the patch applied connect your cam on your network
- register one user with password
- try to access the cam via chrome or other using : http://[IP ADDRESS] : [PORT] /CGIProxy.fcgi?cmd=snapPiture2&usr=[USER]&pwd=[PASSWORD]
normally it should work (that's what I've done to get mine work)
let me know
PS : Without doing all of this maybe try to correct the address you use with mine above I think you've done something wrong here
cheers
Posted: Wednesday 27 April 2016 17:20
by mvveelen
Having some problems with installing the patch. Keep getting a message that the install failed. I'm trying this wireless, what shouldn't be any problem.
Any tips?
