Page 1 of 3
[513] Google Nest Protect (Smoke + CO sensor) support
Posted: Wednesday 06 May 2015 22:29
by Skorpion
It would be really nice if the Google Nest
Protect can be supported in Domoticz. (Not to be mistaken with the Google Nest Thermostat. The request for the Google Nest Thermostat can be found here:
http://www.domoticz.com/forum/viewtopic.php?f=5&t=6077)
- Read status of Protect in Domoticz so interaction with LUA/Blocky events are possible. E.g. Open curtains/roller shutters and turn lights on when alarm goes off.
Maybe it even is possible to use the PIR's of the protect to be used with other actuators etc.
The link to the tracker can be found here:
http://www.domoticz.com/forum/tracker.php?p=2&t=513
Re: [513] Google Nest Protect (Smoke + CO sensor) support
Posted: Monday 29 June 2015 3:58
by Skorpion
Did some searching and I found the code for the Nest thermostat & Protect plugin for the Vera controller. Does anyone know if this is easy adjustable to work with Domoticz?
Git code:
https://github.com/watou/vera-nest/tree/master/src
Readme/explanation:
http://watou.github.io/vera-nest/
Posted: Monday 03 August 2015 21:01
by tomeaton
Has anyone had any luck with this?
Posted: Sunday 30 August 2015 13:19
by tcviper
Same question, has support been implemented yet for Nest Protect?
Would love to see that next to the Thermostat.
Posted: Sunday 06 September 2015 22:49
by tcviper
Pretty pls
Posted: Wednesday 09 September 2015 21:15
by Sappien
+1
Posted: Wednesday 09 September 2015 22:21
by C4Vette
Have three of these so would be great.
Posted: Friday 16 October 2015 20:32
by franzelare
I'm planning to replace my current smoke sensors because they are over 10 years old, so this would be a great feature!
Posted: Saturday 07 November 2015 10:43
by gizmocuz
Maybe someone with a nest protect can send me a PM with the login details, i then can have a look at implementing this
Posted: Saturday 07 November 2015 14:15
by tcviper
Gizmocuz pm
Posted: Saturday 07 November 2015 20:05
by Alle
I just updated to the new build with Nest protect support(Thank you!), but it get the following error in the log:
Error: Nest: Error login!
Checked my credentials and they are correct...
Posted: Saturday 07 November 2015 20:07
by Derik
wwwwhhhooowwww great option...
Wath version is support?
Protect or protect V2?
Posted: Sunday 08 November 2015 11:45
by tcviper
Should work with both versions
You need to use your email as login and password from home.nest.com
Posted: Sunday 08 November 2015 14:48
by Derik
some one have screendumps...?
Posted: Sunday 08 November 2015 14:53
by Alle
Doesn't work (at least not for me). I only use Nest Protect, not the thermostat.. Could that be the cause?
*update
With invalid credentials:
2015-11-08 20:44:30.807 Error: Nest: Invalid data received, or invalid username/password!
With valid credentials:
2015-11-08 20:45:04.816 Error: Nest: Error login!
Posted: Friday 20 November 2015 19:27
by Bob123bob
I got the same results
Add device works and the status is correct then there is no update and sometime Nest: Error login! in the log
Posted: Tuesday 24 November 2015 23:09
by PatrickEekhout
Which readouts are possible with Domoticz from the Nest Protect? Can't seem to find it anywhere.
For example, is it possible to readout the current CO-level in ppm with Domoticz?
Posted: Saturday 05 December 2015 15:14
by Clemen
PatrickEekhout wrote:Which readouts are possible with Domoticz from the Nest Protect? Can't seem to find it anywhere.
This is whats supported by the API
https://developer.nest.com/documentatio ... rms-object
But Domoticz only shows a switch, which is alway off. even when there is smoke.
Posted: Sunday 06 December 2015 15:07
by gizmocuz
Well, it's an opensource project, and i made a good start with it
feel free to supply a git patch
Posted: Thursday 31 December 2015 12:57
by bxlouis
Is it normal that the Nest Protect switch type is set to "Lighting 2, AC, Smoke Detector"?
Also, does it make a difference between a CO alert and a Smoke alert?
Thanks and happy new year!
