Get Roomba/Thinking Cleaner Status
Posted: Sunday 19 April 2015 17:20
After getting inspired by this topic http://www.domoticz.com/forum/viewtopic ... bot#p39453 Where the status off the Hombot vacuum cleaner was displayed in Domoticz i got curious to do the same with my Roombo iRobot 587 with the Thinking Cleaner Wifi plate.
But i got a little Stuck.
From the thinking cleaner i now use the status.xml, it containts the following data
Ive changed the Hombot script to the following script:
This results in the following debug log of bash:
Im not that big in scripting so who can give me a help in the right direction?
It probably has something to do with the way the text is written in the Roomba.txt file compared to the Hombot.txt file
In the Hombot it is:
And in the Roomba/Thinking Cleaner it is:
Perhaps its easier to get the satus directly from the Thinking cleaner Json. But thats all very new to me. The have a very detailed API Guide: http://www.thinkingcleaner.com/downloads/TC_API.pdf
Help would be aprecciated.
I the status is working i want to interper the battery charge en wifi signal strength also using the &rssi=10&battery=89 command found in the wiki.
<status>
<name>Thinking</name>
<modelnr>86</modelnr>
<battery_charge>86</battery_charge>
<cleaner_state>st_wait</cleaner_state>
<cleaning>0</cleaning>
<near_homebase>1</near_homebase>
<bin_status>0</bin_status>
<cleaning_time>54</cleaning_time>
<light_bump>0</light_bump>
<virtual_wall>0</virtual_wall>
<wall>0</wall>
<bumper_state>0</bumper_state>
</status>Code: Select all
#!/bin/bash
# Settings
ROOMBAIP="192.168.165.23" # Roomba IP Address
DOMO_IP="192.168.165.10" # Domoticz IP Address
DOMO_PORT="9090" # Domoticz Port
ROOMBA_STATUS_IDX="123" # Roomba status IDX
ROOMBA_BATTERY_STATUS_IDX="your text switch IDX" # Roomba Battery status IDX
#Get data from status.txt and place text status.txt in new file named Roomba.txt
curl http://$ROOMBAIP/status.xml > Roomba.txt
#EXAMPLE /WORKING/You can name this word here to whatever you like/g' Roomba.txt
sed -i 's/st_base/On homebase: Not Charging/g' Roomba.txt
sed -i 's/st_base_recon/On homebase: Reconditioning Charging/g' Roomba.txt
sed -i 's/st_base_full/On homebase: Full Charging/g' Roomba.txt
sed -i 's/st_base_trickle/On homebase: Trickle Charging/g' Roomba.txt
sed -i 's/st_base_wait/On homebase: Waiting/g' Roomba.txt
sed -i 's/st_plug/Plugged in: Not Charging/g' Roomba.txt
sed -i 's/st_plug_recon/Plugged in: Reconditioning Charging/g' Roomba.txt
sed -i 's/st_plug_full/Plugged in: Full Charging/g' Roomba.txt
sed -i 's/st_plug_trickle/Plugged in: Trickle Charging/g' Roomba.txt
sed -i 's/st_plug_wait/Plugged in: Waiting/g' Roomba.txt
sed -i 's/st_stopped/Stopped/g' Roomba.txt
sed -i 's/st_clean/Cleaning/g' Roomba.txt
sed -i 's/st_cleanstop/Stopped with cleaning/g' Roomba.txt
sed -i 's/st_clean_spot/Spot cleaning/g' Roomba.txt
sed -i 's/st_clean_max/Max cleaning/g' Roomba.txt
sed -i 's/st_delayed/Delayed cleaning will start soon ../g' Roomba.txt
sed -i 's/st_dock/Searching Homebase/g' Roomba.txt
sed -i 's/st_pickup/Roomba picked up/g' Roomba.txt
sed -i 's/st_remote/Remote control driving/g' Roomba.txt
sed -i 's/st_wait/Waiting for command/g' Roomba.txt
sed -i 's/st_off/Off/g' Roomba.txt
sed -i 's/st_error/Error/g' Roomba.txt
sed -i 's/st_locate/Find me!/g' Roomba.txt
sed -i 's/st_unknown/Unknown state/g' Roomba.txt
# Roomba Status
RoombaStatus=`grep -oP '(?<=cleaner_state=").*(?<=")' Roomba.txt`
#Remove "" Characters from string
#RoombaStatus=`echo $RoombaStatus | sed -e 's/^"//' -e 's/"$//'`
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$ROOMBA_STATUS_IDX&nvalue=0&svalue=$RoombaStatus"
pi@raspberrypi:~/domoticz/scripts/bash$ bash -x Roomba.sh
+ ROOMBAIP=192.168.165.23
+ DOMO_IP=192.168.165.10
+ DOMO_PORT=9090
+ ROOMBA_STATUS_IDX=123
+ ROOMBA_BATTERY_STATUS_IDX='your text switch IDX'
+ curl http://192.168.165.23/status.json
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 276 0 276 0 0 3416 0 --:--:-- --:--:-- --:--:-- 4928
+ sed -i 's/st_base/On homebase: Not Charging/g' Roomba.txt
+ sed -i 's/st_base_recon/On homebase: Reconditioning Charging/g' Roomba.txt
+ sed -i 's/st_base_full/On homebase: Full Charging/g' Roomba.txt
+ sed -i 's/st_base_trickle/On homebase: Trickle Charging/g' Roomba.txt
+ sed -i 's/st_base_wait/On homebase: Waiting/g' Roomba.txt
+ sed -i 's/st_plug/Plugged in: Not Charging/g' Roomba.txt
+ sed -i 's/st_plug_recon/Plugged in: Reconditioning Charging/g' Roomba.txt
+ sed -i 's/st_plug_full/Plugged in: Full Charging/g' Roomba.txt
+ sed -i 's/st_plug_trickle/Plugged in: Trickle Charging/g' Roomba.txt
+ sed -i 's/st_plug_wait/Plugged in: Waiting/g' Roomba.txt
+ sed -i s/st_stopped/Stopped/g Roomba.txt
+ sed -i s/st_clean/Cleaning/g Roomba.txt
+ sed -i 's/st_cleanstop/Stopped with cleaning/g' Roomba.txt
+ sed -i 's/st_clean_spot/Spot cleaning/g' Roomba.txt
+ sed -i 's/st_clean_max/Max cleaning/g' Roomba.txt
+ sed -i 's/st_delayed/Delayed cleaning will start soon ../g' Roomba.txt
+ sed -i 's/st_dock/Searching Homebase/g' Roomba.txt
+ sed -i 's/st_pickup/Roomba picked up/g' Roomba.txt
+ sed -i 's/st_remote/Remote control driving/g' Roomba.txt
+ sed -i 's/st_wait/Waiting for command/g' Roomba.txt
+ sed -i s/st_off/Off/g Roomba.txt
+ sed -i s/st_error/Error/g Roomba.txt
+ sed -i 's/st_locate/Find me!/g' Roomba.txt
+ sed -i 's/st_unknown/Unknown state/g' Roomba.txt
++ grep -oP '(?<=cleaner_state" :").*(?<=")' Roomba.txt
+ RoombaStatus=
+ curl -s -i -H 'Accept: application/json' 'http://192.168.165.10:9090/json.htm?type=command¶m=udevice&idx=123&nvalue=0&svalue='
HTTP/1.0 200 OK
Content-Length: 53
Content-Type: application/json;charset=UTF-8
Cache-Control: no-cache
Pragma: no-cache
"status" : "OK",
"title" : "Update Device"
JSON_ROBOT_STATE="CHARGING"Code: Select all
<cleaner_state>st_wait</cleaner_state>Help would be aprecciated.
