installing Mertik controller
Posted: Tuesday 14 April 2015 11:31
by hanss74
I can find that the Mertik controller is fully usable.
However I cannot control it except for On and OFF
How should I add the Mertik controller to my Domoticz application.
I used DIMMER but that does give the full functionality.
I am running Domoticz 2.2284 and the latest RFXtrx relaese.
Thanks for any help.
Re: installing Mertik controller
Posted: Tuesday 14 April 2015 14:30
by hanss74
Sorry,
this should be :
I used DIMMER but that does NOT give the full functionality.
Posted: Thursday 16 April 2015 11:56
by jompie
You can add it as a normal on/off switch and you need to update your domoticz to a newer (beta) version. Else it will not work
Posted: Thursday 16 April 2015 17:31
by hanss74
thank you I am going to follow your advise.
Posted: Friday 17 April 2015 10:22
by hanss74
I followed your instructions and it solved the problem.
Thanks Hans
Posted: Sunday 01 November 2015 7:48
by MjayDB
A little more help on with this please.
I have the latest beta version and added the mertik as an on/off switch. But how can I make a (block/LUA) script like this..
if temp huiskamer (Netatmo) is < 19 then run up kachel
if temp huiskamer (Netatmo) is > 22 then run down kachel
I can only do a run down/up when I change te switch to the run down command (grey arrow down) or grey arrow up for the run up command?
Posted: Wednesday 23 December 2015 22:56
by Zwollenaar
i have an Mertik G6R-H4T-Z2 controller
In the rfxmngr i am able to controle the fireplace.
In domoticz, the learn option only detects up.
When added, i cannot control it.
How can i setup the mertik controller manually ie. one succesfully sended command is:
Thermostat3 command
Packettype = Thermostat3
subtype = Mertik G6R-H4TB, G6R-H4T5, G6R-H4T, G6R-H4TV21-Z22
Sequence nbr = 45
ID = 0x30ECB
Command = Up
Signal level = 0 -120dBi
What should the settings be, its now like (but ain't working)
Switch type: Selector
Type: Selector Switch
ID 0 03 0E CB
Unit code?
And when you want to test the settings, the "ON" command is send, but the fireplace does not respond to an "On"command.
Posted: Sunday 27 December 2015 19:48
by JeroenL
Dear all,
How did you guys make this work? I do not find any options for the Mertik (G6R - H4T1)
Using Raspberry Pi / Domioticz 2.3530 / RFXcom433E
Thanks for any further suggestions. Jeroen
Posted: Thursday 10 March 2016 18:46
by JeroenL
Dear all,
Quick update of what I tried, but still not working:
Upgraded firmware RfxCom 433E from 248-->249-->250-->10001
Disabled all other protocols, ony Mertik active
Used the windows program RfxMgr, no signal detected (other protocols are detected)
Upgraded Domoticz to 3.4834
Anyone any clue? Faulty Rfxcom perhaps??
Best regards, Jeroen
Posted: Monday 25 April 2016 11:22
by JeroenL
Dear all,
Problem solved
Needed to sent my remote control to RfxCOM who have issued a new firmware version. Loading this new FW version fixed it. I can now fully control my fireplace (on/off/ramp up/ramp down).
A big thank you to RFXCOM for helping me out! (within one day! )
rgds Jeroen
Posted: Friday 14 October 2016 20:54
by abc1000
I'v an issue with Mertik G6R-H4T-Z2.
In RFXmngr i can send all commands to the receiver , in the fireplace.
Thermostat3 command
subtype = Mertik G6R-H4S
Sequence nbr = 9
ID = 0x31CB3 decimal:203955
Command = Up
Signal level = 0 -120dBm
Packettype = Receiver/Transmitter Message
subtype = Transmitter Response
Sequence nbr = 9
response = ACK, data correct transmitted
But via Domoticz V3.5763 it is receiving nothing.
With remote control (Mertik G6R-H4T-Z2), Domoticz received all the command..
I can't find the problem, please help..
Posted: Monday 17 October 2016 8:19
by abc1000
update..
I'v changed subtype in the database and now it works!
I didn't see how else to change it.
Someone a tip?
Posted: Wednesday 24 October 2018 19:56
by vfjelde
An old post, but did anyone of you get Mertik remote work in Domoticz? If so, do you have any tip/guide how to get it working?
Posted: Sunday 06 January 2019 10:35
by fl1p
MjayDB wrote: Sunday 01 November 2015 7:48
Pushing this up
I'm also trying to do this, but can't find "up" or "run up" in the blockly.
