2015-03-27 20:07:01.529 Info, Node006, Value::Set - COMMAND_CLASS_SWITCH_BINARY - Switch - 0 - 1 - True
2015-03-27 20:07:01.529 Info, Node006, SwitchBinary::Set - Setting node 6 to On
2015-03-27 20:07:01.529 Detail, Node006, Queuing (Send) SwitchBinaryCmd_Set (Node=6): 0x01, 0x0a, 0x00, 0x13, 0x06, 0x03, 0x25, 0x01, 0xff, 0x25, 0x08, 0x15
2015-03-27 20:07:01.529 Detail, Node006, Queuing (Send) SwitchBinaryCmd_Get (Node=6): 0x01, 0x09, 0x00, 0x13, 0x06, 0x02, 0x25, 0x02, 0x25, 0x09, 0xea
2015-03-27 20:07:01.530 Detail,
2015-03-27 20:07:01.530 Info, Node006, Sending (Send) message (Callback ID=0x08, Expected Reply=0x13) - SwitchBinaryCmd_Set (Node=6): 0x01, 0x0a, 0x00, 0x13, 0x06, 0x03, 0x25, 0x01, 0xff, 0x25, 0x08, 0x15
2015-03-27 20:07:01.538 Detail, Node006, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2015-03-27 20:07:01.538 Detail, Node006, ZW_SEND_DATA delivered to Z-Wave stack
2015-03-27 20:07:01.550 Detail, Node006, Received: 0x01, 0x05, 0x00, 0x13, 0x08, 0x00, 0xe1
2015-03-27 20:07:01.551 Detail, Node006, ZW_SEND_DATA Request with callback ID 0x08 received (expected 0x08)
2015-03-27 20:07:01.551 Info, Node006, Request RTT 20 Average Request RTT 18
2015-03-27 20:07:01.551 Detail, Node006, Expected reply was received
2015-03-27 20:07:01.551 Detail, Node006, Message transaction complete
2015-03-27 20:07:01.551 Detail, Node006, Removing current message
2015-03-27 20:07:01.551 Info, Node006, Sending (Send) message (Callback ID=0x09, Expected Reply=0x04) - SwitchBinaryCmd_Get (Node=6): 0x01, 0x09, 0x00, 0x13, 0x06, 0x02, 0x25, 0x02, 0x25, 0x09, 0xea
2015-03-27 20:07:01.556 Detail, Node006, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2015-03-27 20:07:01.556 Detail, Node006, ZW_SEND_DATA delivered to Z-Wave stack
2015-03-27 20:07:01.751 Detail, Node006, Received: 0x01, 0x05, 0x00, 0x13, 0x09, 0x01, 0xe1
2015-03-27 20:07:01.751 Detail, Node006, ZW_SEND_DATA Request with callback ID 0x09 received (expected 0x09)
2015-03-27 20:07:01.751 Info, Node006, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2015-03-27 20:07:01.751 Warning, Node006, WARNING: Device is not a sleeping node.
2015-03-27 20:07:41.551 Detail,
2015-03-27 20:07:41.551 Info, Node006, Sending (Send) message (Attempt 2, Callback ID=0x0a, Expected Reply=0x04) - SwitchBinaryCmd_Get (Node=6): 0x01, 0x09, 0x00, 0x13, 0x06, 0x02, 0x25, 0x02, 0x25, 0x0a, 0xe9
2015-03-27 20:07:41.553 Info, mgr, Manager::WriteConfig completed for driver with home ID of 0x0184df2b
2015-03-27 20:07:41.558 Detail, Node006, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2015-03-27 20:07:41.558 Detail, Node006, ZW_SEND_DATA delivered to Z-Wave stack
2015-03-27 20:07:41.703 Detail, Node006, Received: 0x01, 0x05, 0x00, 0x13, 0x0a, 0x00, 0xe3
2015-03-27 20:07:41.703 Detail, Node006, ZW_SEND_DATA Request with callback ID 0x0a received (expected 0x0a)
2015-03-27 20:07:41.703 Info, Node006, Request RTT 151 Average Request RTT 84
2015-03-27 20:07:41.710 Detail, Node006, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x06, 0x03, 0x25, 0x03, 0xff, 0x2e
2015-03-27 20:07:41.710 Info, Node006, Response RTT 158 Average Response RTT 91
2015-03-27 20:07:41.710 Info, Node006, Received SwitchBinary report from node 6: level=On
2015-03-27 20:07:41.710 Detail, Node006, Refreshed Value: old value=false, new value=true, type=bool
2015-03-27 20:07:41.710 Detail, Node006, Changes to this value are not verified
2015-03-27 20:07:41.710 Detail, Node006, Expected reply and command class was received
2015-03-27 20:07:41.710 Detail, Node006, Message transaction complete
2015-03-27 20:07:41.710 Detail, Node006, Removing current message
2015-03-27 20:07:41.736 Detail, Node006, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x06, 0x03, 0x25, 0x03, 0xff, 0x2e
2015-03-27 20:07:41.736 Info, Node006, Received SwitchBinary report from node 6: level=On
2015-03-27 20:07:41.736 Detail, Node006, Refreshed Value: old value=true, new value=true, type=bool
2015-03-27 20:07:41.736 Detail, Node006, Changes to this value are not verified
2015-03-27 20:07:41.802 Detail, Node006, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x06, 0x03, 0x25, 0x03, 0xff, 0x2e
2015-03-27 20:07:41.802 Info, Node006, Received SwitchBinary report from node 6: level=On
2015-03-27 20:07:41.802 Detail, Node006, Refreshed Value: old value=true, new value=true, type=bool
2015-03-27 20:07:41.802 Detail, Node006, Changes to this value are not verified
2015-03-27 20:07:41.827 Detail, Node006, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x06, 0x03, 0x25, 0x03, 0xff, 0x2e
2015-03-27 20:07:41.827 Info, Node006, Received SwitchBinary report from node 6: level=On
2015-03-27 20:07:41.827 Detail, Node006, Refreshed Value: old value=true, new value=true, type=bool
2015-03-27 20:07:41.827 Detail, Node006, Changes to this value are not verified
2015-03-27 20:07:41.894 Detail, Node006, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x06, 0x03, 0x25, 0x03, 0xff, 0x2e
2015-03-27 20:07:41.894 Info, Node006, Received SwitchBinary report from node 6: level=On
2015-03-27 20:07:41.894 Detail, Node006, Refreshed Value: old value=true, new value=true, type=bool
2015-03-27 20:07:41.894 Detail, Node006, Changes to this value are not verified
2015-03-27 20:07:41.980 Detail, Node006, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x06, 0x03, 0x25, 0x03, 0xff, 0x2e
2015-03-27 20:07:41.980 Info, Node006, Received SwitchBinary report from node 6: level=On
2015-03-27 20:07:41.980 Detail, Node006, Refreshed Value: old value=true, new value=true, type=bool
2015-03-27 20:07:41.980 Detail, Node006, Changes to this value are not verified
