Fibaro RGBW controller and RGB-ledstrip
Posted: Monday 16 March 2015 19:10
by xayide
I havenfibaro RGBW controller with attached RGB-only ledstrip. When i adjust color the led is turned off (led level / intensity is set to 0). I guess I need to set some value to make the controller and/or domoticz to understand that the ledstrip does not have white attached. Anyone knows how i can do that?
Re: Fibaro RGBW controller and RGB-ledstrip
Posted: Tuesday 24 November 2015 9:02
by tinidk
I am having the same problem. Did you find a Fix ?
Posted: Sunday 13 December 2015 22:56
by tinidk
I got it working, its almost a complete fix, and it is working fine for my.
You need to change to things, first i set parameter 14 to 14
then i set parameter 71 to turn on all when brightness is set to 0
This makes the strip white, when choosing anyting close to white. Otherwise it would turn off, since the W component of the RGBW is set to 100.
There are probably a couple of colors that i can't set, but you don't really notice.
If the system should behave diffently, i think you should be able to choose between RGB and RGBW in domoticz, when you edit the switch type
