Move from RPI B+ to RPI2
Posted: Sunday 01 March 2015 21:04
by tcviper
Hello all,
Has anyone tried moving an existing working SD Card install of domoticz (latest beta build) from RPI B+ model to the new RPI2?
Does anyone know what the steps would be to make it work again or it it will just work as is?
Thx.
Re: Move from RPI B+ to RPI2
Posted: Sunday 01 March 2015 22:39
by antwan
Use search on this forum.
Posted: Saturday 04 April 2015 11:24
by tcviper
I did and i find 100's of threads but nothing specific on if i can just put the current SD card and copy that to a Micro SD and put that in my new RPI2 (coming from RPI).
Posted: Saturday 04 April 2015 14:22
by roblom
Try making a backup of the database on the RPi B+(under settings "Restore/Backup" tab). Then install a fresh installation (see WIKI) and then import the backed up databases from the RPi B+.
Posted: Tuesday 10 November 2015 11:24
by dijkdj
Did you succeed? I'm thinking about doiing the same
Posted: Tuesday 10 November 2015 14:03
by oliviers
I moved from a Raspberry Pi B (512MB) to a Raspberry PI 2B (1MB) simply by moving the microsd card (which, on the R pi B, was in an SD adapter).
It worked instantaneously, but much faster
Oliviers
Posted: Tuesday 10 November 2015 14:11
by oliviers
If you need to copy the SD card to a microsd, this can be done with Win32Diskimager. First "read" the SD card to do a backup, then restore it on a microsd of the same (or higher) capacity.
Olivier
Posted: Thursday 14 January 2016 21:46
by stuiow
oliviers wrote:If you need to copy the SD card to a microsd, this can be done with Win32Diskimager. First "read" the SD card to do a backup, then restore it on a microsd of the same (or higher) capacity.
Olivier
Does this work without any other step's needed? - Like formatting the new microsd card first/installing raspberian first on new card?!
I'm about to do this in the next few days.
Posted: Tuesday 19 January 2016 11:56
by Justino
Olivier
Wind32diskimager will format the sdcard as needed.
So no extra steps needed :D
Posted: Saturday 06 February 2016 15:41
by paulD
good to know. thanks,
