Security Panel
Posted: Saturday 28 February 2015 17:53
by Het-Licht
Anybody an ida how to get the security panel in the switches tab ? I found the the security panel should be in the device list but I can't find it the so it's impossible to ad it to switches. Anybody an idea ?
Re: Security Panel
Posted: Sunday 01 March 2015 11:06
by geronimobb
I'm not sure, but i think after if you use it once from -> setup -> more options -> security panel, it should appear also in your device list.
Grtz.
Re: Security Panel
Posted: Sunday 01 March 2015 11:52
by jin
Het-Licht wrote:Anybody an ida how to get the security panel in the switches tab ? I found the the security panel should be in the device list but I can't find it the so it's impossible to ad it to switches. Anybody an idea ?
Do you have configured a PIN code from Setup menu?
SecPanel automatically appears into Switches tab when you setup a PIN code.
Re: Security Panel
Posted: Sunday 01 March 2015 12:35
by Het-Licht
Got it, appeared after i set the pin code! Thanks!
Re: Security Panel
Posted: Tuesday 09 February 2016 15:16
by groetg
Also with the pin code set it won't Work on my banana pi.
What could be the problem?
Re: Security Panel
Posted: Tuesday 09 February 2016 16:40
by groetg
When i visited http://<IP-domoticz>:8080/secpanel/index.html I tried to arm the panel, after that the switch appeared.
Re: Security Panel
Posted: Tuesday 09 February 2016 19:00
by groetg
had same problem. Solution no user and password than it works well.
Re: Security Panel
Posted: Friday 08 April 2016 17:57
by elgarne
I can see a security panel in my devices after adding a pin code, deleting username/password, and arming home/away.
Adding this device to the map does not allow me to change the status nor to access the panel to enter the pin code. When I press the button, I have the following message:
Erreur d'envoi de la commande à l’interrupteur, vérifiez le dispositif/matériel !
which means
error sending command to the switch, please verify device/hardware
How do you proceed please? Thanks.
PS: I'm using V3.4855
Re: Security Panel
Posted: Sunday 26 November 2017 13:17
by TheTambu
with version 3.8153 the Security Panel can be found in the Setup->Device list as "Domoticz Security Panel", and needs to be manually added to the used devices. After it can be found in the Swithces panel and eventually added to the Dashboard.
Re: Security Panel
Posted: Wednesday 06 December 2017 22:14
by quilae
Just for information: To make this work it is necessary to have Domoticz accept new hardware devices. It took me 15 minutes before I realized my mistake.
B.T.W.: I think the timers function is wrong here. If I set a timer I only have the option to set it on or off. So what's the on state here? Is it armed home or armed away. I didn't try this because I use this switch in a different way.
