Problem adding Weather Underground
Posted: Friday 20 February 2015 17:16
by Iron Man
I see all of you have done a pretty good job with the frontpage. I also have been busy with it but had some trouble with the weather forecast.
I noticed that my Domoticz won’t accept my virtual weather underground and I keep getting an error that the http can’t be reached or something.
I hoped someone could help me with that.
I also have tried to get the forecast information of the api page. The page url would be something like "
http://api.wunderground.com/api/"+api+" ... ion+".json" this is what I used in javascript, but I can’t get the information of the page.
I really hope somebody can help me with one of these things.
Kind regards,
Rob van Hoof
Posted: Friday 20 February 2015 17:46
by Iron Man
@mvveelen thanks for your fast reply
I have tried your suggestion but still get the error:
"Fri Feb 20 17:30:00 2015 Error: Wunderground: Error getting http data!"
At the moment I have used this as setting:
(I would have post a image but I don't know how xD)
Posted: Friday 20 February 2015 17:49
by mvveelen
And 'Bladel' is the exact name of the weatherstation that is the nearest? Normally they have a slightly different name (and I think also in capitals), like 1BLADEL or something like that.
Oh, and posting images is very easy, just use the tab "Upload attachment" and then use the inline option.
Posted: Friday 20 February 2015 17:55
by Iron Man
Oke thanks,
This are my settings at the moment:
But the exact name of the weather station is: INOORDBR26 and it is located in “Hapert”.
Posted: Friday 20 February 2015 18:55
by SwordFish
Iron Man wrote:Oke thanks,
I used for location helmond_netherlands
Posted: Friday 20 February 2015 19:05
by Iron Man
I have tried your suggestion. I tried “bladel_netherlands” and “hapert_netherlands” but I still get the same error. But still thanks for your replay.
Posted: Friday 20 February 2015 19:32
by mvveelen
Have you tried:
pws:INOORDBR26
or just
INOORDBR26
Walk through all the steps and read carefully. I made the mistake the first time to 'forget' the ' pws: '
edit: I'm using:
pws:IBLOKKER2
Posted: Friday 20 February 2015 19:45
by SwordFish
Is your Api key right?
When I use my api key with bladel_netherlands it works;
- Knipsel.PNG (24.95 KiB) Viewed 7590 times
When I use youre Api (from the screenshot) it doesn't work, So chech if your Api key is correct.
Posted: Friday 20 February 2015 20:22
by Iron Man
mvveelen wrote:Have you tried:
pws:INOORDBR26
or just
INOORDBR26
I already tried that one if i remember right but to be sure I tried it again and still got the error.
I'm sorry I blured out some numbers the api is <API_KEY_removed_by_moderator>
But is you use this link:
http://api.wunderground.com/api/API_KEY ... lands.json
You can see the api is working.
But by some meaning I can't get it to work in my Domoticz sytem.
Posted: Friday 20 February 2015 20:57
by SwordFish
If you install the virtual devices as told in the wiki and you still don't get data then its stops for me, sorry.
Maybe someone else can help you.
Posted: Friday 20 February 2015 21:06
by Iron Man
SwordFish wrote:If you install the virtual devices as told in the wiki and you still don't get data then its stops for me, sorry.
No problem but still really thanks for your help!
Re: Problem adding Weather Underground
Posted: Saturday 21 February 2015 11:00
by ThinkPad
I removed the above posts from this topic:
http://domoticz.com/forum/viewtopic.php ... &start=420 because they were too much offtopic there.
Please create a new topic for problems you encounter that have nothing to do with the topic you were posting in
Oh and by the way, i have removed your API key from posts in this topic. This forum is also indexed by Google, so everyone can find your API-key, and use it if they want. It is advisable to ask WU for a new API-key, as this one is maybe already used by others now. API-key is a personal key, not meant to be shared with others.
Posted: Wednesday 13 January 2016 21:21
by HansLe
Hi, I've the same problem. Used the URL with my app key and location and get the weather information. Using the api key and location in domoticz is not working. I get the following message in the log file :Error: ForecastIO: Invalid data received!
Were you able to solve it?
Posted: Thursday 14 January 2016 17:09
by HansLe
OMG what a .... I was. I selected the first "Forecast IO (Weather lookup)". Searching the program sources I saw Wunderground.cpp. Back to domotecz and selected "Weather underground". All the devices came by the wind
