Raspberry, webcam och Domoticz
Posted: Thursday 12 February 2015 19:57
by Quart
I got a USB camera Logitech C270 connected and I have tried Motion and fswebcam and it works perfect and takes nice pictures.
But I want to use this raspberry and webcam as "webcamserver" so that I can get snapshots in Domoticz.
I have a couple of Axis cameras and Dlink with those cameras I can use wget and fetch a image.
Is there a software that I can use with the raspberry that function the same way ?
Re: Raspberry, webcam och Domoticz
Posted: Friday 13 February 2015 16:53
by Mince Inside
This should be possible with Motion
http://www.raspberrypi.org/forums/viewt ... 61#p374790
Just set the port number not to be the same as any other web services running on the Pi and you should be good.
Have a look here 1st
http://www.domoticz.com/wiki/Camera_Setup#USB_Camera
Posted: Friday 13 February 2015 18:09
by Quart
Thanks for your answer.
I plan to put this rasberry pointing my parkinglot.
I have my other raspberry running Domoticz
So using uvccapture is no option.
Motion is working fine but I cant take "snapshots" from it on demand only on specified time like each 5 minutes or so.
Posted: Friday 13 February 2015 18:59
by Mince Inside
There must be a URL for snap shot - ie what is being sent every 5 mins as a command?
Posted: Friday 13 February 2015 21:24
by Quart
In Motion conf you can specify time when snapshot will be taken
Posted: Sunday 30 August 2015 20:51
by Dlanor
Mince Inside wrote:There must be a URL for snap shot - ie what is being sent every 5 mins as a command?
Which imageurl needs to be used when you want to use FSwebcam (and not uvccapture)?
Posted: Tuesday 10 November 2015 19:33
by Paul
Yeah same with my old webcam, works in fswebcam and do not want overhead of motion running, should be possible to use fswebcam as command to trigger image capture rather than uvccapture
