Page 1 of 2
Domoticz on OpenWRT
Posted: Friday 06 February 2015 8:15
by athtest800
Hello.
I am looking on purchasing openWRT router.
Will Domoticz run on this platform?
How much space does it needs?
Thank you!
Re: Domoticz on OpenWRT
Posted: Friday 06 February 2015 10:52
by ThinkPad
Just buy a Raspberry Pi, will make it a lot easier.
Raspberry Pi is cheap and uses very little power (4-5W).
Posted: Tuesday 10 February 2015 9:18
by A1AD
ThinkPad wrote:Just buy a Raspberry Pi, will make it a lot easier.
You are absolutly right, but i realy like the idea! Domoticz running on my OpenWRT router would be awesome!
Posted: Tuesday 10 February 2015 9:26
by ThinkPad
I think the CPU and RAM of a router are too limited for a full blown package like Domoticz. But hey, your free to try :)
Posted: Tuesday 10 February 2015 23:02
by pwhooftman
Google "Domoticz on OpenWRT", first hit....
Posted: Friday 13 February 2015 13:40
by KingOfNuls
ThinkPad wrote:Raspberry Pi is cheap and uses very little power (4-5W).
The same goes for a mini router less expansive (ie tp-link 703N or http://www.dx.com/fr/p/gl-inet-wi-fi-ro ... N2hf_nh08o )
Posted: Sunday 15 February 2015 15:05
by irimi
athtest800 wrote:Hello.
Thank you!
Please AudiculaPi topic.
http://www.domoticz.com/forum/viewtopic.php?f=17&t=4909
There is also a openwrt feed/Makefile available that makes it possible to compile domoticz for other targets:
src-git audiculapi http://git.code.sf.net/p/audiculapi/code
Posted: Friday 01 July 2016 11:50
by kosten
Hi.
I'm trying to publish domoticz in OpenWRT main package repository. Here's may pull request https://github.com/openwrt/packages/pull/2883
The basis of the project I took https://sourceforge.net/projects/audiculapi/
Any suggestions are welcome.
Posted: Wednesday 24 August 2016 5:54
by andriej
Hi, can you please do a such pull request on the lede-project?
Since it's spinoff with much brigther future, it's much bigger chance to get domoticz ran there.
Soon they will release stable version with newest kernel and security patches, which might be important.
Get more info at: https://www.lede-project.org/ and https://github.com/lede-project/source
Posted: Friday 16 September 2016 14:30
by kofec
Lede and openwrt are using the same repo for "comunity" packages. Maybe some can help to finish this https://github.com/openwrt/packages/pull/2883 pull request
I was able to run Domoticz on my router (Xiaomi Mini)base on padavan firmware using this commit
https://github.com/Entware-ng/Entware-ng/issues/333
Posted: Saturday 17 December 2016 16:36
by Timeless
@Kosten, I just added a reply to your pull request @git with a package Makefile configuration that works for me. It uses both the newest releases for Domoticz & Open-Zwave.
I will also add it to this post for people that are interested, see:
Domoticz_Open-Zwave.zip
Makefiles for Open-Zwave and Domoticz
(3.59 KiB) Downloaded 344 times
I'm currently using LEDE Reboot (checkout from yesterday)
Timeless
Posted: Tuesday 27 December 2016 12:13
by Timeless
Copy of my git pull request comment:
I updated the makefiles and also included WiringPi. Which could be used in combination with Domoticz. Currently both the Static and Dynamic linked library are being build. Domoticz needs the library to be static-linked but I had another project that needed a dynamic-linked library as well. So that's why they are both there.
Ideally we could have a Dynamic library and a separate Static library. Please let me know your opinion.
Here is the ZIP archive:
Domoticz & Open-Zwave & WiringPi.zip
(5 KiB) Downloaded 249 times
I have to add that I'm using a resulted build on a RPI3 for 1 week now. Which is running fine with a Z-Wave stick, RFXcom433e and several GPIO accessories.
If anyone is interested in a complete LEDE build let me know! Suggest your target so I know what to include.
Regards,
Timeless
Posted: Friday 30 December 2016 12:16
by derrij
I would like to have domoticz for Xiaomi Router 3.
Thank you.
Posted: Wednesday 04 January 2017 11:56
by Timeless
Sorry but the Xiaomi Router 3 is not supported by OpenWRT/LEDE.
Posted: Saturday 22 April 2017 9:18
by vasko
Timeless wrote:Hi,
Here is the ZIP archive: Domoticz & Open-Zwave & WiringPi.zip
Regards,
Timeless
Hi Timeless.
I have a TP-Link TL-WDR4300 router running Lede 17.01.1. Would it be possible to build Domoticz for this device?
I see it is available in packages souorce tree but I can not find built package.
Thanks in advance
Posted: Friday 23 June 2017 8:55
by szurke
It is very interest for me also. I have an ASUS AC-87U and I would be running on it a small Domoticz server. But I didn't find any compiled Domoticz package on the web. Is it possible at all?
Thx
Posted: Tuesday 18 July 2017 11:29
by Timeless
HI,
Sorry for my late reply, but Domoticz is now officially supported in OpenWRT/LEDE. It has not made it to the latest LEDE 17.01.2 release but will be in the next release. However it is possible to run LEDE latest snapshot and install Domoticz & OpenZwave. But please keep in mind these snapshots are only valid for a limited time because they are nightly builds, so if a packages changes it can quickly become incompatible with your running snapshot whenever you run "opkg".
The supported Domoticz version in LEDE/OpenWRT is 3.5877 which is the latest release, but since I need a more updated version of Domoticz I've not tested the official LEDE/OpenWRT version myself, and I'm still using my own Makefiles. But the official version should work.
As an example, the x86-64 build for Domoticz(LEDE/OpenWRT) can be found here. But it would also be possible to run:
opkg update && opkg install domoticz
from within a freshly installed snapshot LEDE/OpenWRT
Hope this helps.
Regards,
Timeless
Posted: Tuesday 25 July 2017 18:39
by szurke
Hi Timeless,
Thank You so much! It is working without any problem.
Regards,
Krisztian
Posted: Wednesday 09 August 2017 13:06
by HM31
Has anyone tried to install it on the Onion omega2 chip that seems to turn LEDE ?
Posted: Friday 18 August 2017 3:40
by HM31
Answer to myself : Installation done.
1. Configure Onion Omega 2+ for Wifi as describe in Onion documentation (in fact I did a fresh reset to factory settings install)
2. Switch back to using the official LEDE repos as described here : https://docs.onion.io/omega2-docs/using-opkg.html
3. reboot
opkg update
opkg install domoticz openzwave
reboot
6. access to your omega2 using http://<your ip address>:8080
You get the Domoticz web page ready to configure. :D
Still not tried to connect my RFXCom or Zwave USB dongle for now but soon ...I hope.
