Return water temperature on Intergas HReco36
Posted: Tuesday 13 January 2015 19:46
by cp9999
I have installed an OTGW last week on my installation (Intergas HREco36 with an Honeywell Chronotherm Touch Modulation).
It all seems so work fine, except for the Return water temperature which is reported as 0 degrees.
I checked the return water temperature directly on the Honeywell thermostat and it also reports 0 degrees.
Now I'm worried that the return water sensor is either defect or not connected properly (or just not reported on OpenTherm by the boiler).
Question:
Is there anyone with an Intergas HReco36 that can tell me if the Return water temperature is reported through OpenTherm?
Re: Return water temperature on Intergas HReco36
Posted: Sunday 01 February 2015 16:08
by Juan
I have the OTGW connected to an Intergas Kombi Kompakt HR 28/24 and also no Return water temperature indication.
I think it's not reported via the Open Therm protocol although it should (boiler matrix point 28 OTGW website)..
When the sensor would be defect, the boiler should give an error code in it's display and probably not functioning anymore.
But.... if anyone knows a solution for this, please leave a note
Posted: Friday 06 February 2015 20:25
by Newwolf
Got the same problem, but when I look at Opentherm Monitor it's also not giving me the return water. (or I wasn't that patience)
So I think it's more a firmware problem as a Domoticz problem.
Grz.,
Jos
Posted: Saturday 07 February 2015 22:16
by roblom
Same here, I have a Remeha Calenta and this should give the Return Water temperature but in Domoticz it stays on 0,0.
Posted: Saturday 07 February 2015 23:28
by roblom
Found it, you need to add the AA=28
Posted: Monday 09 February 2015 20:54
by Newwolf
Okay nice, but is this possible to set from or in Domoticz or do I have to disconnect OTGW and configure it every update on the PC?
Posted: Thursday 12 February 2015 23:05
by roblom
Newwolf wrote:Okay nice, but is this possible to set from or in Domoticz or do I have to disconnect OTGW and configure it every update on the PC?
You need to set it by using the otmonitor once. Then it will be remembered by the OTGW. The otmonitor can run also in raspbian.
Posted: Tuesday 17 February 2015 14:26
by Newwolf
Thanks for the reply.
Already found a good way how to do this.
Maybe nice for people how not found a way:
http://www.domoticz.com/forum/viewtopic ... 738#p34738
Posted: Tuesday 17 February 2015 22:19
by roblom
That works too but the OTGW remembers the setting so connect it to a laptop of PC with the OTmonitor on it and you are able to activate the setting there.
Posted: Tuesday 19 January 2016 22:53
by Relight
Just wanted to add to this thread this really worked for my Remeha Calanta as well.
The thread may miss some info for the new user (like me) .
# start to otmonitor.exe
# enter settings
# go to miscellanious
# enter AA=28 in the command windown & press SEND
# press done & go to the log window
# you will see the command stream by
# if you now are patient for a minute or so you will see the retrun water entry getting updated
The interval is a bit high so it may need a little time to get populated. You can also look at the statistics screen for the value.
Posted: Monday 08 February 2016 10:42
by Draakje
People please stay on topic.
The topic is about a Intergas HReco36 boiler.
As I am also a owner of this type of boiler I would also like to know if it is possible to read out the return temperature.
Did someone got it operational?
Posted: Wednesday 11 January 2017 9:54
by CaptainSlow
I've send the command with domoticz. Go to hardware and click on setup of your hardware item (your OTGW). There you can send any OTGW command. You don't need otmonitor for it.
Works perfectly and now I got the return item value as well....
Note: strange...on the otgw website on this link
http://otgw.tclcode.com/matrix.cgi#boilers it says that my remeha tzerra does not support this data-id but it does....
willem
