New Raspberry1-2B+ Images based on OpenWRT (Update 3.5877)
irimi
Domoticz version: V4.10717
Post by irimi »
I would like to recommend my new special Raspberry image update to v2015-03-25:
AudiculaPi - the tiny media server for your Raspberry Pi
now with Domoticz v3.4834
based on OpenWRT Barrier Breaker 14.07, r44952
resp for RPI Model 2B+ update to v2015-08-18:
with Domoticz V3.5412 and OpenZWave 1.4.340
Preinstalled Raspberry Pi image (only 37MB compressed size) is available at
Sourceforge: AudiculaPi
Features:
* Minimalistic system, installed and running on a just 256MB sized SD card
* AudiculaPi provides a detailed Web Browser GUI for system setup with multi language support
(http://[RPI's IP ADRESS])
* Countless packages available at OpenWRT Barrier Breaker repository (see WebGUI -> System -> Packetmanager)
* Domoticz V2.x
Successfully tested with HW: RFXtrx433E USB 433.92MHz Transceiver by RFXCom and Z-Wave Plus USB Stick ZME_UZB1 by Z-Wave.me / OpenZWave V1.3.112
Regulary updates of domoticzs/openzwave available via packagemanager (see below)
Already preinstalled, too:
* MPD / Music Player Daemon - Internet Radio / MP3 /OGG / FLAC etc. player
(with LIRC & bluetooth remote control support, LCD support based on PyDPF)
* IPTV / DVB-T/S/C recorder with TVHeadEnd 3.9 / MuMuDVB 2 (recent git versions)
* SAMBA Server
* SSH/SFTP Server
* MiniDLNA
* Shairport
* Avahi
* OpenVPN
* WebCAM Video Streaming with mjpeg-streamer
* NTP client / server
* WLAN client and / or access point
* Firewall
[Update]
For latest update to domoticz r2.0.x , openzwave etc. use packetmanager !
Just type
opkg update
opkg upgrade domoticz openzwave userland
/etc/init.d/domoticz restart
Or use Web GUI -> System->Packetmanger -> Update Packages, install domoticz
If all goes fine you'll get something like this:
Upgrading domoticz on root from 2.0.2195-1 to 2.0.2209-2...
Downloading http://sourceforge.net/projects/audiculapi/files/v2015-01-10/packages/audiculapi/domoticz_2.0.2209-2_brcm2708.ipk.
Installing openzwave (1.2.919-1) to root...
Downloading http://sourceforge.net/projects/audiculapi/files/v2015-01-10/packages/audiculapi/openzwave_1.2.919-1_brcm2708.ipk.
Installing udev (173-1) to root...
Downloading http://downloads.openwrt.org/barrier_breaker/14.07/brcm2708/generic/packages/base/udev_173-1_brcm2708.ipk.
Installing wiringpi (20150107-1) to root...
Downloading http://sourceforge.net/projects/audiculapi/files/v2015-01-10/packages/audiculapi/wiringpi_20150107-1_brcm2708.ipk.
Removing obsolete file /opt/domoticz/www/views/test.html.
Configuring udev.
Configuring openzwave.
Configuring wiringpi.
Configuring domoticz.
root@AudiculaPi:/mnt/media# /etc/init.d/domoticz restart
2015-01-17 11:52:05 Domoticz V2.2209 (c)2012-2014 GizMoCuz
2015-01-17 11:52:05 System: Raspberry Pi
2015-01-17 11:52:05 Startup Path: /opt/domoticz/
domoticz: Domoticz is starting up....
Cheers, irimi
Derik
Re: New Raspberry Image based on OpenWRT
Post by Derik »
Picture of this
Looks nice
I have openWrt on my router.... [ and love this ]
Is there a link possible between both?
irimi
Post by irimi »
Which kind of link do you mean ?
Heisenberg
Post by Heisenberg »
Very nice!
Raspberry Pi Type B
Raspberry Pi Type B2
RFXCOMtrx433e
Derik
Post by Derik »
irimi wrote:Which kind of link do you mean ?
Are there more options possible with open wrt on my router and Domoticz openwrt..?
Is there perhaps an option that i can use my opnwrtrpi as a wifi repeater?
irimi
Post by irimi »
Derik wrote: Is there perhaps an option that i can use my opnwrtrpi as a wifi repeater?
Yes, that's possible!
See details at http://wiki.openwrt.org/doc/recipes/relayclient
Required packages relayd and luci-proto-relay are already installed.
You only have to connect wifi hardware to RPI's usb interface and you have to install the driver manually if it's not the preinstalled kmod-rt2800 (depends on your hw).
Most linux wifi drivers are avaible as kmod package.
ThinkPad
Post by ThinkPad »
Topic moved to 'Compatibility' section.
irimi
Re: New Raspberry Image based on OpenWRT (Update r2209)
Post by irimi »
New update to domoticz r2209 is available, please see first message
Heisenberg
what's the password to logon? the default pw doesn't work in CLI
Also notification via email doesn't work anymore...?
Raspberry Pi Type B
RFXCOMtrx433e
irimi
Post by irimi »
Heisenberg wrote:what's the password to logon? the default pw doesn't work in CLI
As described in README default access is:
user:root
PW:[empty]
Since you have not changed only Web GUI or telnet login is possible but no ssh !
email notifications: I have no idea :( , I just compiled recent version, now with openzwave and GPIO support ???
Heisenberg
Ok thnx for your quick reply. I didn't read the Readme properly. My bad!
Raspberry Pi Type B
RFXCOMtrx433e
irimi
Re: New Raspberry Image based on OpenWRT (Update r2241)
Post by irimi »
Update to domoticz to 2.0.2241 is available
now with
openzwave update to v1.3.999 and
userland / RPI tools provide raspicam applications, too
BUT, things I have observed: :o
  • Cpu load now varies with peaks up to 14%
  • I get the message web "brower refresh cache failed"
Heisenberg
I also get error message 'Resource fetch failed (404)" but everythings seems to work except e-mail notifications (credentials are correct though)
Raspberry Pi Type B
RFXCOMtrx433e
irimi
Re: New Raspberry Image based on OpenWRT (Update r2250)
Post by irimi »
Update to r2250 is avaiable, now with openzwave v1.3.1001 support.
Browser cache problem is still unsolved,
r2252 causes segmentations faults on my system
KingOfNuls
Post by KingOfNuls »
Very interesting. I'll give it a chance because i want to try to connect my pi to my visonic powermaster with the viknet software (on openwrt - TP-Link 703N).
About the cache problem, i've got it behind my workplace proxy with a sort of filtering. Perhaps an openwrt rule not allows it.
Could you write an how to compile domoticz for openwrt, pleeeeaaaaaaaase ?
RPI B - domotiga connected to my visonic alarm
RPI 2 - domoticz connected to 1 wire temp sensors and teleinfo ("power smartmeter")
RPI 3 - domoticz master with mysensors and RFLink gateways
irimi
Post by irimi »
KingOfNuls wrote: Could you write an how to compile domoticz for openwrt, pleeeeaaaaaaaase ?
There is a openwrt feed available for the required Makefiles:
src-git audiculapi http://git.code.sf.net/p/audiculapi/code
How to use feeds please see at openwrt wiki.
irimi
Re: New Raspberry Image based on OpenWRT (Update r2269)
Post by irimi »
Update to v2.2269 , OpenZWave 1.3.1015 and Raspi usertools is available via packetmanager.
max_g
Post by max_g »
Great work Iremi
your efforts will be apreciated by many people.
Many of the rasberry pi users run with a rfxtrx.com 433 tranceiver which i understand you support but can you also confirm if the PIface switch and sensor block is also supported by your image ?
Many thanks
max i mus
irimi
Post by irimi »
max_g wrote:but can you also confirm if the PIface switch and sensor block is also supported by your image ?
No, in recent version PiFace is not supported. But which libs/packages are required for that support. I can try to add them.
As I see
irimi
Re: New Raspberry Image based on OpenWRT (Update r2294)
Post by irimi »
Update to Domoticz v2.2294 & OpenzWave V1.3.1025 is avaible via packetmanager.
