IR-Schreib-Lesekopf
Posted: Friday 02 January 2015 12:34
by jossie67
I have Landis+Gyr ZME120ACd and a IR-Schreib-Lesekopf from Udo
The IR-Schreib-Lesekopf is connected to the raspberry on /dev/ttyUSB0
I added the IR-Schreib-Lesekopf as an "SO Meter USB" on serial port /dev/ttyUSB0.
In the setup, I can change to Baudrate only to 9600 or 115200, my Landis+Gyr uses 300 Baud.
Where can I change this setting in to 300 Baud.
Re: IR-Schreib-Lesekopf
Posted: Monday 30 March 2015 18:15
by Dlanor
I have the same kind of problem with my Landis+Gyr ZCF120ABd. I won't get any reading from IR-Schreib-Lesekopf on my RPI.
pi@RaspberryPi ls -l /dev/serial/{by-path,by-id}/*
lrwxrwxrwx 1 root root 13 Jan  1  1970 /dev/serial/by-id/usb-RFXCOM_RFXtrx433_A1YI4T4I-if00-port0 -> ../../ttyUSB1
lrwxrwxrwx 1 root root 13 Jan  1  1970 /dev/serial/by-id/usb-Silicon_Labs_USB-IR-Kopf_0092D858-if00-port0 -> ../../ttyUSB0
lrwxrwxrwx 1 root root 13 Jan  1  1970 /dev/serial/by-path/platform-bcm2708_usb-usb-0:1.2:1.0-port0 -> ../../ttyUSB1
lrwxrwxrwx 1 root root 13 Jan  1  1970 /dev/serial/by-path/platform-bcm2708_usb-usb-0:1.3:1.0-port0 -> ../../ttyUSB0
[b]pi@RaspberryPi ~ $ cu -l /dev/ttyUSB0 -s=9600 --parity=none[/b]
Connected.
Nothing pops up on my RPI. I have tested the IR-Schreib-Lesekopf with my windows laptop. It shows up and reads the data.
Posted: Monday 30 March 2015 19:31
by ThinkPad
The output looks quite similar to that of a smartmeter, but similar != same.
I think Domoticz can't parse it, because it doesn't know this kind of telegram.
Maybe it can be implemented :)
Posted: Tuesday 31 March 2015 22:52
by pj-r
Bit offtopic but can anyone say if I can buy ready assembled IR-Schreib-Lesekopf from somewhere?
Posted: Thursday 02 April 2015 10:33
by Dlanor
pj-r wrote:Bit offtopic but can anyone say if I can buy ready assembled IR-Schreib-Lesekopf from somewhere?
Via volkszaehler.org
Posted: Thursday 02 April 2015 10:36
by Dlanor
ThinkPad wrote:The output looks quite similar to that of a smartmeter, but similar != same.
How can i send the request to be implemented?
Posted: Thursday 02 April 2015 10:49
by ThinkPad
You can place a feature request here: http://www.domoticz.com/forum/tracker.php?p=2 and discuss about it here: http://www.domoticz.com/forum/viewforum.php?f=5 (be sure to read the rules of that subforum).
Posted: Friday 03 April 2015 9:04
by gizmocuz
I think for one reason is that the P1 serial port is opened with 9600 baud, Even parity, 7 bits
Maybe your serial protocol is different ?
what you can try:
install 'ser2net' and configure this that port 2000 is opening the right serial device, with the right parameters (in raw mode)
now when you connect from another machine to this port 2000, you should see the serial output
in domoticz, you can also setup a P1 meter with LAN interface
Maybe this will work
Probably later this year you will get a P1 Smart meter (i think everyone in holland will get one)
Posted: Friday 03 April 2015 16:44
by jossie67
Gizmocuz,
I don't think I will get a new smart-meter this year, my house was build in 2008.
I have it working now also with stadverwarming, see also
http://www.domoticz.com/forum/viewtopic.php?f=14&t=5270
Posted: Saturday 04 April 2015 9:47
by Dlanor
gizmocuz wrote:Probably later this year you will get a P1 Smart meter (i think everyone in holland will get one)
I have called Stedin en our area isn't scheduled yet. They have planned it somewhere from 2017 until 2020. Just because it is working fine for them now.
Posted: Saturday 04 April 2015 11:22
by Domosapiens
In our area ENEXIS is the provider.
When I called them to tell that my meter didn't switch from high to low tariff,
it was immediate replaced by a smart meter.
In my case it was the truth (but who cares?).
Hope this helps
Domosapiens
Posted: Saturday 13 June 2015 21:03
by Dlanor
I have tried to get my Lesekopf working. I am getting one step closer but am stil far far away. I am sending
pi@raspberrypi ~ $ echo -e "\x2f\x3f\x21\x0d\x0a" > /dev/ttyUSB0
pi@raspberrypi ~ $ cat /dev/ttyUSB0
(ER23)
Does anybody knows more?
Posted: Tuesday 07 July 2015 10:42
by jossie67
Dlanor wrote:I have tried to get my Lesekopf working. I am getting one step closer but am stil far far away. I am sending
Check viewtopic.php?f=31&t=5390 and viewtopic.php?f=14&t=5270
IR-Schreib-Lesekopf
Posted: Tuesday 07 July 2015 17:33
by Dlanor
Thanks! I will give it a try. I give up and wait for support within Domoticz :oops: . Too much noob for this.
Posted: Wednesday 20 April 2016 22:53
by Jendemen
How do I see on what USB port the IR-Lesekopf is connected?
When I use 'dmesg | grep ttyUSB' I see nothing, so it is a bit difficult to amend the python script which reads the Kamstrup.
Posted: Saturday 29 September 2018 11:04
by Dlanor
Dlanor wrote: Tuesday 07 July 2015 17:33
Finally allmost got it working. Babysteps! @Jossie67 thanks!
